Old 05-26-2008, 14:07   #1 (permalink)
MARK26's Avatar
Member: 626582
Thanks Meter: 15
Help! how to find similar firmware
Hi Infinity Team... I have a dead china phone. I tried all the firmware that match or almost close to the firmware that I'm looking for but I can't revive it. Once, I used some firmware in the support area that is almost similar to what I'm looking for but the phone is only in white screen. I tried to search in the forum and I read that erasing the flash chip and writing another firmware can solve the problem but I doubt it, because I once did it in N73 china... and the unit is not responding anymore when I hold the power button when flashing it. Please help. Tnx.
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:0FAE:0884
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:2CEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5A0A257B.[KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN_60B13AAA].rpl
identification#1 detection finished
device-id: 5A0A257B
identification#1 protocol ver: 04
ver. sw1: KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN
ver. sw2: MAUI.06B.W07.04.MP.V32, 55C54E9F
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [flash[KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN]]...
warning: wrong data size at 0x00040800, retry...
error: too many retries during read operation
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
operation canceled by user
file saved: C:\Program Files\InfinityBox\ChineseMiracle\n95 customer his art\backup_flash[KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04 _MP_V32.BIN]_20080524-134804.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _5A0A257B_KONGLI26_06B_PCB01_GPRS_MT6226_S01.MAUI_ 06B_W07_04_MP_V32.BIN_60B13AAA_20080524-134828.B0X.bin
Finished, time used: 279 sec
Remove/Install battery now !
Old 05-26-2008, 14:11   #2 (permalink)
GsmFreeShop's Avatar
Member: 567723
Thanks Meter: 314
Try with this solution bro it's work for me when i can't found any firmware that match with my phone
1-Full erase ship
2- flash eeprom with this eeprom file
Get It
3- now flash your phone with any fw + eeprom (from support )
4- if dont work reflash eeprom with this file :
Get It
NB
eeprom and flash file must be the same version
alll done no dead phone
br
>>> GsmFreeShop <<<
Old 05-26-2008, 19:38   #3 (permalink)
MARK26's Avatar
Member: 626582
Thanks Meter: 15
thank you so much GSMfreeShop.. I am gonna try that and post the result
Old 05-27-2008, 08:23   #4 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
i Advise u to just REad a forum little before posting .. there are very competent peoples there for Help if peoples want it...
just see this .. not a very far .. but a sticky thread....
http:///vbb/showpo...82&postcount=1
Old 05-28-2008, 13:21   #5 (permalink)
MARK26's Avatar
Member: 626582
Thanks Meter: 15
>>> GsmFreeShop <<<
Thank you so much for sharing your ideas in reviving my china fone! I revived the unit after doing exactly what you said. Sharing really gained respect!
here is the log:
COM4 [VCP3] selected
advanced flash detection disabled
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
Boot...
19200 fixed
Connecting, wait...
CPU: MT6226
high speed disabled
Boot Done
Initialize...
flash: EC257E25082501:FFFFFF00000000
flash: Samsung D 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_***x_***x.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
standard eeprom/ffs offset assigned: 00E00000
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
ffs chip: 00
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80528-172944.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
.damaged firmware
.damaged hardware
security area#1 calculation...
done
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization...
Finalization Done
Finished, time used: 1937 sec
Action: imei
Model: Autodetect 6205-6227 NOR
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: AT+EGMR=0,0
Hardware version: MT6226, E02
Software version: Kongli26_06B_HW"
Software date: MAUI.06B.W
Barcode: 2005.04.12
imei write method: mode-1
new imei: 357927005281012
imei verification failed
Finished, time used: 50 sec
Power off phone now !
@ .::BHATTI::.
I always use search button before asking for help. I check the site you posted, I already know how to find a firmware. My question here is i don't understand why I can't revive the unit while I already used a similar or almost close to the firmware that I'm looking for. It takes courage to post for help in a forum. Have great day
HELP how to unlock iphone 3.1 laksh007 iPhone 2 / iPhone 3G / iPhone 3GS 7 03-31-2010 03:22
How to find arabic firmware ? aminnovelty NSPRO 3 10-23-2009 11:32
GUIDE: How to Find the Firmware and Baseband Version of Your iPhone dubaimobiles iPhone 2 / iPhone 3G / iPhone 3GS 3 02-10-2009 20:46
How to find branded firmware? MrPiercer Nokia Base Band 5 ( BB-5 ) 0 02-26-2007 11:12
Who can send me or help me to find flash file for GD70 v22A or similar??? starpho Panasonic 0 10-05-2001 02:38
Page generated in 0.21917 seconds with 9 queries
