Old 04-04-2008, 14:48   #1 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
n73 2sim dead
@infinityteam i have a n73 2sim dead..... i try some flash file with some flash mobile is on !! but no display incoming & out going ok but when i try some another flash file only NOKIA on display
this is details
COM28 [VCP1] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6219:8B02:8B01]...
CPU: MT6219
high speed boot enabled
CPU: MT6226MA detected
chip: 0031:3A41:3C08
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
921600
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom/ffs area
Do you want to use standard ffs address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard ffs address selected by user
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Finished, time used: 91 sec
Remove/Install battery now !
waiting ............................................
Old 04-04-2008, 14:56   #2 (permalink)
Ravvi's Avatar
Member: 611165
Thanks Meter: 36
hello bro....make format ffs & write imei also..
Old 04-04-2008, 15:03   #3 (permalink)
Member: 70916
Thanks Meter: 56
hai dude if u have full flash backup then write it back set will be ok
other wise u have to read flash from same model of working set
Old 04-05-2008, 04:42   #4 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
if i have a backup then i am posting here and yes not also same mobile yet ......if u have then give me read ok flash
Old 04-05-2008, 04:46   #5 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
this is the image of that mobile
Old 04-05-2008, 07:09   #6 (permalink)
doller's Avatar
Member: 524817
Thanks Meter: 206
eeprm not detect so no way to complet
doller
Old 04-05-2008, 07:44   #7 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
i flash with this file
CM_Nokia-N73C-2sim_ZX860_THLD_PCB01_GPRS_MT6226_S01[1].ZX860_THL_1_1_16m_En_n.B0M
mobile in on but just chines language on display
Old 04-05-2008, 10:02   #8 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
After write the above file ....
Boot...
19200 fixed
Connecting, wait...
CPU: MT6219
Boot Done
Initialize...
Initialize Done
Set baud...
921600
Set baud Done
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.F5FB7B98.[ZX860_THLD_PCB01_GPRS_MT6226_S01.ZX860_THL_1_1.BIN _2D0D50ED].rpl
identification#1 detection finished
device-id: F5FB7B98
identification#1 protocol ver: 04
ver. sw1: ZX860_THLD_PCB01_GPRS_MT6226_S01.ZX860_THL_1_1.BIN
ver. sw2: ZX860_THL_1.1, 12AFF2D2
ffs offset/size: 00E00000/00200000
standard eeprom/ffs offset detected: 00E00000
eeprom/ffs found near: 00E00000
ffs chip: 00
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _F5FB7B98_ZX860_THLD_PCB01_GPRS_MT6226_S01.ZX860_T HL_1_1.BIN_2D0D50ED_20080405-015919.B0X.bin
Finished, time used: 73 sec
and here is the backup of eeprom file http://rapidshare.com/files/10500402...0.B0E.rar.html
Old 04-05-2008, 17:51   #9 (permalink)
Member: 130995
Thanks Meter: 35,227
Nice..
Now you have new experience: you can find in support area any file that you need, just need to try several files and spend some time. Nothing hard, just need to be patient.
How to set English: *#0044# or *#001#
Old 04-07-2008, 06:52   #10 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
Originally Posted by InfinitySupport View Post
Nice..
yes boss i try with that but nothing change to language
Old 04-07-2008, 17:39   #11 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
sometimes need to type *#0044# and after this green (send) button
Old 04-08-2008, 07:36   #12 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
hello!
yes i try this but not change the language in english..
Old 04-08-2008, 11:33   #13 (permalink)
Member: 130995
hello!
sometimes need to type *#001# and after this green (send) button
Old 05-28-2008, 11:11   #14 (permalink)
kalpeshoza's Avatar
Member: 462292
Thanks Meter: 397
problem is slove bye new update thanks here is http:///vbb/showthread.php?t=542766
n73 2sim pinout MaHmUt1982 Infinity-Box 1 05-30-2008 07:10
i want pinout N73s 2sim 2x5 IkaMazini Infinity-Box 1 05-05-2008 13:34
n82 2sim dead after flashing with file from support patric Infinity-Box 3 04-17-2008 20:08
N66 2sim Dead MED9 Infinity-Box 3 01-24-2008 20:07
N95 2sim dead after flash!! majidjony Infinity-Box 4 10-04-2007 00:52
Page generated in 0.31543 seconds with 11 queries
