09-24-2016, 07:48 | #16 (permalink) | |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Quote:
I am having 2 backups now one from faulty cellphone and another from a working phone. Br. | |
09-28-2016, 08:57 | #23 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | Hello, There is the link of a working cellphone's firmware . https://forum.gsmhosting.com/vbb/****************************/?alkukgga600f6gl Infinity Team, If you need to analyse the firmware you can do it. Thank you! Br. |
09-28-2016, 09:03 | #24 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | Hello, I just see my mistake, The cellphone is still stuck and not with me right now. I return to the owner. @destinul as he said, He got the same problem after reset the and he did (Repair Minfo) but nothing happen. Br. |
09-28-2016, 09:14 | #26 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | @Jaydi I call the owner to bring the cellphone back, He brought it back and i did operation as you said, But still same. Code: Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453000DA53B37A3373 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453000DA53B37A3373 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x47F50D0AEA244D9DF3E1AC406360630E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Vodafone ProdName : Smart_mini7 ProdModel : VFD 300 Device : VFD300 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P38 SECURITY : IMEI_OTP [1] : 356774072656309 EXTRA : LCD : Not info available :( LCD Res : 800x480 TOUCH [0] : GT1XX CAM [0] : ov5670_mipi_raw CAM [1] : s5k5e8yx_mipi_raw CAM [2] : ov2680_mipi_raw CAM [3] : gc2355_mipi_raw_rear CAM [4] : gc2355_mipi_raw_front CAM [5] : sp2508_mipi_raw CAM [6] : gc0310_mipi_yuv MODEM : jhz6580_we_vf_m_hspa jhz6580_we_vf_m_gprs LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Fix Android Partitions [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453000DA53B37A3373 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453000DA53B37A3373 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x47F50D0AEA244D9DF3E1AC406360630E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Refill : Cache Refill Ok! Refill : UserData Refill Ok! Repair Rest data .. Repair Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
09-28-2016, 09:16 | #27 (permalink) | |
I already uploaded a working dump! see my post. http://forum.gsmhosting.com/vbb/12066798-post23.html Br. | |
09-28-2016, 09:16 | #28 (permalink) | |
Freak Poster Join Date: Dec 2002 Location: romania Age: 52
Member: 18823 Status: Offline Thanks Meter: 24 | Quote:
Its allready upload. | |
