09-28-2016, 09:39 | #32 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Hello, I have found a working phone, reading dump! The size of dump its too big for me to upload i will try after compress with .7zip . Code: Operation : Read Flash [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453000D9CEA5753301 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453000D9CEA5753301 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x47F50D0AAB35701D2C7D2EFEC4793A6B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Read Ok , collect info Brand : Vodafone ProdName : Smart_mini7 ProdModel : VFD 300 Device : VFD300 AndroidVer: 6.0 MTKxCPU : MT6580 MTKxPRJ : alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P38 Saved to : C:\Users\Shakeel Software\Desktop\VDF 300 DUMP\MT6580__VODAFONE__VFD_300__Smart_mini7__VFD300__alps-mp-m0.mp1-V2.34_jhz6580.weg.vf.m_P38__Android_6.0.ispff Done! Elapsed: 00:15:26 Reconnect Power/Cable! Br. Last edited by Shakeel_pattoki; 09-28-2016 at 09:48. |
10-12-2016, 10:09 | #35 (permalink) |
Member: 437195 Status: Offline Thanks Meter: 1,734 | Look inside the thread , There is a link of uploaded firmware. http://forum.gsmhosting.com/vbb/12066798-post23.html Br. |
10-21-2016, 19:18 | #38 (permalink) | |
Freak Poster Join Date: Sep 2012
Member: 1808452 Status: Offline Thanks Meter: 21 | Quote:
Performed operation as instructed but still won't help Chinese Miracle II [MTK module] v 1.58 Operation : Fix Android Partitions [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530000ADD0EF6339B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530000ADD0EF6339B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x821AAA710797C3187C209181F6ABD33A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Refill : Cache Refill Ok! Refill : UserData Refill Ok! Repair Rest data .. Repair Ok! Done! Elapsed: 00:00:34 Reconnect Power/Cable! Operation : Fix Android Partitions [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530000ADD0EF6339B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530000ADD0EF6339B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x821AAA710797C3187C209181F6ABD33A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Refill : Cache Refill Ok! Refill : UserData Refill Ok! Done! Elapsed: 00:00:36 Reconnect Power/Cable! Couldn't also get approriate Alcatel upgrade tool for the model to do online firmware upgrade Any help please Last edited by busfield; 10-21-2016 at 19:25. | |
10-23-2016, 16:25 | #42 (permalink) |
Freak Poster Join Date: Apr 2007 Location: viet nam
Member: 484531 Status: Offline Thanks Meter: 69 | flash file VD300 SURE 100000% WORKING.test https://www.fshare.vn/file/IPRFIZ9YTWUB |
The Following User Says Thank You to thienglong-tv19 For This Useful Post: |
10-23-2016, 17:12 | #43 (permalink) | |
10-23-2016, 18:31 | #44 (permalink) | |
Here is new development with phone. I just tried to read nvram from phone but this was the result Operation : Read NVRAM [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 110100303034474530000ADD0EF6339B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 110100303034474530000ADD0EF6339B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x821AAA710797C3187C209181F6ABD33A INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Read Error , NVRAM area is blank or damaged Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! Please can anybody help with working nvram backup? I think after writing good nvram, phone will be ok. Thanks | |
10-23-2016, 23:14 | #45 (permalink) | |
