Vodafone Smart_mini7 VFD300 Stuck Hello , The cellphone came for frp reset so i did full factory reset after all its stuck on startup ( A rounding ball ) is appearing since after. Please help Sir. Here is the operations log : Read Info Log : Code: Chinese Miracle II [MTK module] v 1.56 Code: Operation : Format FileSystem [ v1.56 ] |
Hello, Did you made Backup? Reinstall battery (take out and insert battery again), switch ON phone and wait for 2-3 minutes, sometimes this works. Alternatively you can do Repair ExtData and check again. Br. Infinity Box Support Team. |
1 Attachment(s) Quote:
Let me explain i have done alot. I've got backup (full firmware backup) I had try to write back that firmware still same, I did try also ExtData , I did full factory reset more than 3 time before write back and after, I remove battery many times and put it back still same. Some logs are here again. Code: Start at : [9/22/2016 / 5:21:10 PM] Code: Chinese Miracle II [MTK module] v 1.56 |
It MT6580. It can stuk up to 20-25 minutes before first start! Also, alternate way - select second WIPE mode and do format. Run phone and leave it until it boot completely. |
Now i am done again . its been 1 hour now and the phone is stuck still. :( Code: Chinese Miracle II [MTK module] v 1.56 |
@Shakeel_pattoki, Hello, as per Mr Passionate boys question, You have made backup before format or after format operation???? I think there is some problem in mobile firmware. So search working firmware and re-flash it again. Also, Post here HW Test report.. |
Br. |
Please do as I said. It helps sometimes. Thank you... |
As I told you before and as per your report, as the backup is not working. Please try search this firmware with same ver and flash it... also post here hw test reports. |
I didn't even find fresh firmware over the Google . Br. |
HW test report Operation : HW Test [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 7 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453000DA53B37A3373 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 0EG40 [eMMC] : FLASH_CID : 11010030303447453000DA53B37A3373 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0x47F50D0AEA244D9DF3E1AC406360630E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3717 mV [Processing] FlashMemory Read-Write test [eMMC] : [TOSHIBA] , 0EG40 , 0xEC000000 , 3776 MiB [eMMC] : CID : 11010030303447453000DA53B37A3373 [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:38 Reconnect Power/Cable! |
Post here scatter file from that FW. Just scatter file. |
I have found another working cellphone in my hands. I have another read file from it. I had done flashing to the old patient still not working. :( Here i am attaching scatter file, Please download it. Br. |
I had checked and didn't found anything strange in it. Simple Alcatel-like. Request - make Flash dump from this faulty device. For emergency case. Select Alcatel. Go to extra tab - alcatel. Do Repair MInfo. |
