Old 01-24-2008, 06:49   #1 (permalink)
dany_kroya81's Avatar
Member: 584778
Thanks Meter: 78
A38 Cant make Call
i have problem with BenQ-Siemens A38 cannot make a call but sms and signal is ok
please help me the solution for this phone
Old 01-24-2008, 06:57   #2 (permalink)
Member: 342909
Thanks Meter: 6
call in or out????? see phone boock menu,and next use search button
Old 01-24-2008, 07:03   #3 (permalink)
Member: 584778
Thanks Meter: 78
call in problem bro....but call out is ok
why this phone like that....?????
Old 01-24-2008, 07:06   #4 (permalink)
Member: 342909
Thanks Meter: 6
see phone boock menu,bro you find solution there b
Old 01-24-2008, 07:13   #5 (permalink)
Member: 342909
Thanks Meter: 6
Go to phone book
Press ok
Scroll down
Private, ok
Select no.
Try calling your number after deactivating the privacy and post results.
The Following 2 Users Say Thank You to tenma For This Useful Post:
Old 01-24-2008, 07:17   #6 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Just upload eeprom with infinity and all will be ok.
Old 01-24-2008, 12:51   #7 (permalink)
Member: 584778
Thanks Meter: 78
the phone when make others card (operator),the phone was no signal.what is the problem ????
this is software or hardware problem ????
can u give me others solution
Old 01-24-2008, 13:29   #8 (permalink)
Member: 130995
Thanks Meter: 35,227
You can try to use "repair eeprom" files for this phone.
Old 01-24-2008, 13:51   #9 (permalink)
Member: 584778
Thanks Meter: 78
flashing with infinity
Log flash with infinity :
COM4 selected
Device: BenQ A38
Checking data, wait...
Action: flash write
Write: Firmware
Skip: Flex
Write: Language Pack
Write: Eeprom
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
203125
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
Check Parameters Done
Check Space...
Flash: 0001:227E221D2200
flash: Amd S29GL032A-U r1,r2,r8,r9 U 4Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Write: Firmware
Write: Eeprom
Writing Done
Finished, time used: 307 sec
Remove/Install battery now !
COM4 selected
Device: BenQ A38
Action: unlock
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
203125
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
error: not locked or unknown eeprom
Check Parameters Fail
Finished, time used: 12 sec
To infinity Supporter :
1. what is wrong with my step,coz the phone always cant accept the call.but make a call is ok.im sorry sir my english so bad and poor
2. BenQ-Siemens A38 dont have Flex ?
Old 01-24-2008, 19:06   #10 (permalink)
Member: 130995
Hello,
it's no need to write Language Pack, it's enough to write only "repair eeprom".
Try to use another eeprom files.
Old 01-25-2008, 04:30   #11 (permalink)
Member: 584778
Thanks Meter: 78
Originally Posted by InfinitySupport View Post
Hello,
its ok the problem solved with write eeprom and used files A38_repair_eeprom_09.6BE
thanks to u infinity supporter......
nice to use infinity.........
this Box is very good and powerfull
The Following User Says Thank You to dany_kroya81 For This Useful Post:
Old 05-08-2008, 08:53   #12 (permalink)
ajaycrunch007's Avatar
Member: 506395
Thanks Meter: 48
Smile tnx
t for ur advice its realyy working tnx
L6 cant make call or make a call sygnal Smart-Clip 4 09-09-2007 06:03
mpx220 only receiving call cant make calls doomstyle Motorola ODM 0 03-16-2006 12:24
Help After flashing K700 phone cant make call or receiving Call Weasley Cruiser Suite 2 07-11-2005 17:14
Anonimus OK but cant make call dominik Infineon C16X M51 & ARM7 M52 BASED 2 02-08-2002 13:45
SAGEM 922 CANT MAKE CALL wild Sagem Hardware Repair Area 1 10-19-2001 08:35
Page generated in 0.20971 seconds with 9 queries
