11-05-2010, 11:56 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | vodafone543 dead after unlock i try to unlock vodafone 543 but after unlock its dead and sorry to say i did not make backup before unlock any way to alive it now here is the log COM2 [VCP8] selected module v3.63 Device: Alcatel-543X Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001603:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: i:\Program Files\InfinityBox\MModule\backup_security\id.28A34 D09.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 28A34D09 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 4A27C435 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 264 provider: 543X-2AVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 warning: wrong data size at 0x00AE2800, retry... read error recovered flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC01 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003194012 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: i:\Program Files\InfinityBox\MModule\backup_security\Alcatel-543X_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_ 40_SP1_V32_F3__system_log_28A34D09_35C4274A_201011 05-152254.B0X.bin Finished, time used: 4 min 22 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
11-05-2010, 12:22 | #2 (permalink) |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | phone alive after flash with this version 543X-2AVDGB1-264_XN26FC00_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_ 08A_W08_40_SP1_V32_F3_2010-05-12_En_Fr_Es_It_De.B0M.bin COM2 [VCP8] selected module v3.63 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 543X-2AVDGB1-264_XN26FC00_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_ 08A_W08_40_SP1_V32_F3_2010-05-12_En_Fr_Es_It_De.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001603:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: i:\Program Files\InfinityBox\MModule\backup_security\id.28A34 D09.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 28A34D09 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 4A27C435 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 264 provider: 543X-2AVDGB1 customization: CN26FC01 customization: XN26FC01 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is invalid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003194012 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader (file) is present: 00020000 rom info relocation detected startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: i:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_28A34D09_35C4274A_2010110 5-161758.B0X.bin Area: Firmware flash: 98006F00000004:09EA0000000000 Write: Firmware usb bootloader (file) is present: 00020000 rom info relocation detected sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... search sec info#2 finished searching sec info#3... search sec info#3 finished number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN264013 warning: customization name is unknown name table[01] #7000000 detected customization: CN26FC00 customization name adjusted customization: CN26FC00 customization name adjusted customization detected: CN26FC00 customization: CN26FC00 flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #9000000 detected customization: SN264013 warning: customization name is unknown name table[01] #7000000 detected customization: CN26FC00 customization name adjusted customization: CN26FC00 customization name adjusted customization detected: CN26FC00 customization: CN26FC00 flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: i:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_28A34D09_35C4274A_2010110 5-162158.B0X.bin Finished, time used: 5 min 27 sec Remove/Install battery now ! br |
11-05-2010, 12:27 | #3 (permalink) |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | unlock done COM2 [VCP8] selected module v3.63 Device: Vodafone-543 Checking data, wait... advanced flash detection enabled Action: rebuild security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001603:A00E status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98006F00000004:09EA0000000000 flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb otp offset: 01FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00020000 searching rom info... search rom info finished rom info structure: [protected] type (07), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: i:\Program Files\InfinityBox\MModule\backup_security\id.28A34 D09.[JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN_35C4274A].rpl rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 28A34D09 rom info ver: 07 sw version: JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_40_SP 1_V32_F3.BIN project-id: MAUI.08A.W08.40.SP1.V32.F3, 4A27C435 code offset: 00020000 ffs offset/size [01]: 01800000/00800000 TCL-ID identification version: 264 provider: 543X-2AVDGB1 customization: CN26FC00 customization: XN26FC00 TCL-ID identification done rom info structure: [protected] type (07), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 01800000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is invalid area3 is valid area4 is invalid searching sec info#2... search sec info#2 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#3... search sec info#3 finished sim-lock status: enabled product id: JRDHUIZHOU_MT6225_OTMINI_SERIES area1 is valid area2 is valid area3 is valid area4 is valid number of sec info areas: 3 security area (sec info, cust) calculation... error: security area (sec info, cust) header is invalid security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC00 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done security area (sec info, cust) calculation... identification header detected customization: XN26FC00 customization name adjusted flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 98006F00000004:09EA0000000000 flash: 98006F00000004:09EA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35982003194012 flash: 98006F00000004:09EA0000000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 98006F00000004:09EA0000000000 Finalization Done file saved: i:\Program Files\InfinityBox\MModule\backup_security\Vodafone-543_JRD25_08A_PCB01_GPRS_MT6225_S00.MAUI_08A_W08_4 0_SP1_V32_F3__system_log_28A34D09_35C4274A_2010110 5-162812.B0X.bin Finished, time used: 4 min 18 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! all fine now thanks br |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
