06-24-2008, 17:25 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: algerie
Member: 643285 Status: Offline Thanks Meter: 11 | vodaphone 125 COM16 [VCP0] selected Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: E:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20080624-172250.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: E:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20080624-172255.B1E.bin reading [eeprom-complete]... file saved: E:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20080624-172302.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 45 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following 2 Users Say Thank You to brahim12 For This Useful Post: |
06-24-2008, 21:04 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
07-06-2008, 08:05 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: shandar chock jelum pakistan
Member: 241661 Status: Offline Thanks Meter: 265 | i hve tryed with infinty but something is wrong SIM SPERRE BLOCKIERT TELEFON that comes up when i insert sim so help needed?????????????????? |
07-06-2008, 08:10 | #4 (permalink) |
Freak Poster Join Date: May 2001 Age: 58
Member: 4434 Status: Offline Thanks Meter: 20 | After unlock procedure enter code 12345678 manu times (7-8 times) and phone is unlocked. Tested on manu phones. |
The Following User Says Thank You to sb323ar For This Useful Post: |
Vodaphone 125 is sucessufully unlocked | zeerik | Infinity-Box | 21 | 03-06-2018 03:22 |
vodaphone 125 pin out cannot find by pin finder | rohit50 | Infinity-Box | 12 | 04-28-2009 19:20 |
vodaphone 125 | ranagaurav | Infinity-Box | 2 | 01-26-2009 18:18 |
vodaphon 125 unlock not ok | tuanlinh_qtri1 | Infinity-Box | 11 | 12-15-2008 10:45 |
vodaphone 125 ERROR | mags | SMTi | 2 | 07-07-2008 20:04 |
