07-31-2008, 13:16 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Vodaphone 125 is sucessufully unlocked vodaphone 125 unlock successfully.................thanks infinity team COM13 selected Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20080731-193306.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20080731-193310.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20080731-193319.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 51 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 |
The Following User Says Thank You to zeerik For This Useful Post: |
07-31-2008, 19:26 | #5 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | bro if you believe then listen this phone is unlocked by my 4 years old son i only adjust cable the rest work with computer done by him...........i also have sagDD but my first choice is infinity box .........check your cable ...set baud rate 115200 .....if you have not cable then you can use charging jack of TREND T100 ......I=TX....2=RX.....3=GND ......Enjoy |
08-01-2008, 08:05 | #8 (permalink) |
Freak Poster Join Date: Dec 2004 Location: UNITED KINGDOM
Member: 96918 Status: Offline Sonork: 100.1602725 Thanks Meter: 32 | i have problam infinity unlocked sucessufully but phone is still locked then i try to unlock again but software says phone is already unlocked what can i do Device: ZTE-125 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:22C4 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sta_20080801-115152.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-sec_20080801-115156.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-125_eeprom-complete_20080801-115203.B1E.bin reading additional data... done backup critical area Done Check memory... current status: #2, already unlocked already done (mode-0), operation aborted Check memory Failed Finished, Remove/Install battery now ! Time used: 35 sec |
08-01-2008, 09:34 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Location: Vietnam Age: 50
Member: 149256 Status: Offline Thanks Meter: 285 | Quote:
08-01-2008, 10:45 | #10 (permalink) | |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Quote:
08-17-2008, 06:08 | #15 (permalink) | |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Quote:
vodaphone 125 pin out cannot find by pin finder | rohit50 | Infinity-Box | 12 | 04-28-2009 19:20 |
vodaphone 125 | ranagaurav | Infinity-Box | 2 | 01-26-2009 18:18 |
vodaphon 125 unlock not ok | tuanlinh_qtri1 | Infinity-Box | 11 | 12-15-2008 10:45 |
vodaphone 125 ERROR | mags | SMTi | 2 | 07-07-2008 20:04 |
vodaphone 125 | brahim12 | Infinity-Box | 3 | 07-06-2008 08:10 |
