Old 01-19-2012, 21:57   #1 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
Vofadone mt6223 how to read ?
I try to read fimware with tp
in model :
Hardware version: MT6223, E08
Hardware version: JRD23_NEP_08A_HW
Software version: MAUI.08A.W08.36.SP1.
Software date: 2000.00.00
Barcode: MT012345678901234567
imei-1: *___*
Finished, time used: 12 sec
because always have in detail info :
Initializing [6223:8A08]...
CPU: MT6223
high speed boot On
chip: 0011:4FE4:A00C
status: 01
warning: unknown or damaged hardware
boot packet size: 0400
error: bootcode start error: A4 not authorized: 000000A4
Release Power button now !
Boot Done
====> Initialize ...
error: no any expected answer : wrong answer after chip cfi request
number of flash chip/regions detected: 00/01
flash chip is unknown or damaged.
Fault reasons:
1. flash chip is damaged: replace or resolder/reball flash chip
2. hardware is damaged: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 30 sec
Remove/Install battery now !
try in NOR , NAND but still same :
module v3.29
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read firmware
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
Boot Done
Fault reasons:
Initialize Fail
Finished, time used: 42 sec
Is there any solution to read firmware /language/ via infinity ?
Old 01-21-2012, 12:01   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
you are using too old software.
upgrade your box to version 1.18 and download latest Mmodule
Old 02-08-2012, 21:00   #3 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
hello!
i UPGRADE BOX AND SOFT , BUT STILL SAME
Old 02-09-2012, 13:34   #4 (permalink)
Member: 148515
hello!
can i see new Log, made by latest Mmodule?
Old 02-15-2012, 13:12   #5 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
hello!
COM10 [VCP0] selected
module v4.16
Device: _Autodetect MT6205-6239 NOR
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: 01
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 21 sec
module v4.16
Device: _Autodetect MT6228-6268 NAND
Action: read flash NAND
interface: BROM_DLL_v3.1016.00
Connect...
bootcode current/expected: 0.0/3.2
CPU: 6223:8A08:8A00
status: 01
bbchip bl ver: FE
NOR flash id[0000]: 0000:000000000000 [AMD] AM29DL323D
chip size: 0Mb
otp status/size: S_DONE/00000000
NAND flash id[0000]: 0000:000000000000 [SAMSUNG] K9F5608Q0C
chip size: 0Mb
page/spare size: 0000/0000
pages per block: 0000
bits i/o: 00
address cycles: 00
internal RAM size: 00000000
external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000
sec error code: AA
error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE
error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE
Disconnect...
done
Finished, time used: 25 sec
Old 02-15-2012, 13:27   #6 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
TRY TO EDIT READED FLASH WITH CHINESE MIRACLE , BUT STILL PROBLEM
Editor version: [2.04] I
Detected crypted Chinese Miracle file...
Crypted fullflash loaded
Loading file... OK
MTK Rom Info Version: 05
ROM version: JRD23_NEP_08A_PCB01_GSM_MT6223_S00.MAUI_08A_W08_36 _SP1_V28_F1.BIN
MCU version: MAUI.08A.W08.36.SP1.V28.F1
Build time: 2011/04/07 13:45
Hardware: JRD23_NEP_08A_HW
More info: MAUI.08A.W08.36.SP1.V28.F1
Searching first signature...
Detecting language pack names and codes...
Memory addressation found
Language pack names and codes detected!
Language table found
Error with analysing firmware found, maybe CPU type not recognised, try select CPU type manually
Old 02-21-2012, 19:25   #7 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
hello!
like you see on earlier post , I read this phone like you wrote .
but is there any solution to change language or edit language in this model ?
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.21127 seconds with 9 queries
