10-20-2015, 11:06 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Voice V10 NAND Unsupported Team Please Check This... The Mobile is ON and Hang on Voice Logo I try to read Information but failed. I have tried almost every available Option But the answer is same. "Where is NIM_Px-2 or NIM_Px-1 mean which one need try. If NIM_Px-2 - then need try P1-2 , P2-2 , P3-2 If NIM_Px-1 - then need try P1-1 , P2-1 , P3-1" If i will post whole Logs much of forum Space will be wasted, Only One Log that will represent all Options. Operational Log: Operation : Check / Read Info [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009A , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:12 Reconnect Power/Cable! TEAM PLEASE GUIDE ME... B/R Sheraz... |
10-20-2015, 11:18 | #2 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | check it bro test reports Voice V10 Voice V10 NAND Factory Firmware & NV read By CM 2 http://forum.gsmhosting.com/vbb/11345411-post16.html Write with SPTool Hang on logo phone success Done http://forum.gsmhosting.com/vbb/11345429-post17.html work for CM 2 Voice V10 NAND invalid imei repair Successfully Don http://forum.gsmhosting.com/vbb/11345777-post22.html |
The Following 4 Users Say Thank You to kabul For This Useful Post: |
10-20-2015, 13:55 | #5 (permalink) |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Bro...MAHABUB... Respected Brother, First of all Recharge Your Mobile Battery Near About 70% then once go for Read Info if info Successful Well and Good If Not Do not be Panic, But Keep in Mind Mobile should have NAND6572 CPU. Download this flash file Voice_V10__MT6572__NAND__hct72_wet_lca By Kabul You can contact Mr.Kabul for flash file and its password His Sonork ID is 100.1661890 Now open SPFT Tool Load the Scattered File and Use the Option Format All+Download And wait until finish. You are Done. Repair IMEI With CM2K After Flash You are now Fully Done... Any thing Else Bro? B/R Sherazz... |
10-20-2015, 14:41 | #9 (permalink) |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Bro...MAHABUB... Yes I am Succeed in Read Flash File After Recharge The Battery. Here are Logs Of Read Flash File. Operation : Check / Read Info [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009A , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Read Flash [ v1.34 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009A , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... [Read Ok] : preloader_hct72_wet_lca.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache_empty.img [Read Ok] : usrdata_empty.img [ScatCFG] : MT6572 / V1.1.1 / hct72_wet_lca / NAND FW Size : 378 MiB Scatter saved to : C:\Users\Mobile Shop\Desktop\MT6572__NAND__hct72_wet_lca Done! Elapsed: 00:03:34 Reconnect Power/Cable! |
The Following User Says Thank You to BISMILLAH MOBILES For This Useful Post: |
10-21-2015, 05:02 | #12 (permalink) | |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Bro.... Quote:
If you do not have their Good And Working Backup just Request at Forum with Logs and you will get your desired Flash files from any Friend who use Infinity CM2K. Hope you got my Point.. B/R Sheraz... | |
10-21-2015, 05:07 | #13 (permalink) |
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | Respected Jaydi Thanks.. BUT One question is still there, As you know every Person make backup before any operation for Emergency Case either it is MTK or SPD. It is strongly recommended by every team that make Backup for emergency before any operation. Is there any chance of mismatch firmware or Boot loader in NAND Chip like MTK rest Chip? Waiting for reply.. Sheraz... |
10-21-2015, 08:21 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SW asking make backup only in one case - Smart AV now. Because we still improving it. In other cases it useless. Just because we are sure in our work. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
