06-13-2015, 11:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2012
Member: 1824929 Status: Offline Thanks Meter: 99 | Voice v40 write flash error ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 46 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D43303447020240C72C700D DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D43303447020240C72C700D [eMMC] : FLASH_LEN : 0x00000000E2C00000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : wt97512 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000600000-0x0000000000100000 Erase : 0x0000000002300000-0x00000000DF820000 Flash Pre-Erase Done, time used : 00:00:22 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_wt97512.bin Preloader Init Failed! Looks like HW error or incompatible image i read this file with cm2 but now its not writing |
06-13-2015, 15:15 | #7 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | Voice V40 already Read write successful report maybe hardware problem http://forum.gsmhosting.com/vbb/11035565-post1275.html http://forum.gsmhosting.com/vbb/11095784-post1661.html |
The Following User Says Thank You to kabul For This Useful Post: |
