01-21-2015, 07:04 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | Vox V5555 failed to write 4th imei Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 76 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : B3C51AFDE3BA82A5B2FED153FAD23617 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6260 SW : MAUI.11B.W13.08.MP.V3.F1 HW : YUANDA60A_COSMOS_11B_HW IMEI[1] : 359454784981889 IMEI[2] : 359454784981889 IMEI[3] : 359454784981889 IMEI[4] : 359454784981889 Update IMEI[1] to : 911322051905806 Update IMEI[2] to : 911322051905814 Update IMEI[3] to : 911322051905822 Update IMEI[4] to : 911322051905822 Verify Failed! Done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! |
01-23-2015, 12:19 | #6 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Can you, finally, explain - does CM2 write them ( at least any ) or not? With such huge count if info - I can just ignore that, because not see problem clearly. |
01-24-2015, 05:08 | #7 (permalink) |
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | Code: Wait for phone... Phone found! [ 76 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : B3C51AFDE3BA82A5B2FED153FAD23617 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C200 2500 3800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E60000-0x00FFFFFF , LEN : 0x001A0000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:01:39 Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 76 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : B3C51AFDE3BA82A5B2FED153FAD23617 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6260 SW : MAUI.11B.W13.08.MP.V3.F1 HW : YUANDA60A_COSMOS_11B_HW IMEI[1] : 359454784981889 IMEI[2] : 359454784981889 IMEI[3] : 359454784981889 IMEI[4] : 359454784981889 Update IMEI[1] to : 911322051905806 Update IMEI[2] to : 911322051905814 Update IMEI[3] to : 911322051905822 Update IMEI[4] to : 911322051905822 Verify Failed! Done! Done! Elapsed: 00:00:36 Reconnect Power/Cable! Operation : Repair Security [ v1.09 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 76 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CA00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : B3C51AFDE3BA82A5B2FED153FAD23617 BROM Protocol Version : 05 Setting Service Mode ... Init Ok, waiting for phone ... Phone Initial Info : BB : MT6260 SW : MAUI.11B.W13.08.MP.V3.F1 HW : YUANDA60A_COSMOS_11B_HW IMEI[1] : 911322051905806 IMEI[2] : 911322051905814 IMEI[3] : 911322051905822 IMEI[4] : 911322051905822 Update IMEI[1] to : 911322051905806 Update IMEI[2] to : 911322051905814 Update IMEI[3] to : 911322051905822 Update IMEI[4] to : 911322051905822 Verify Failed! Done! Done! Elapsed: 00:00:34 |
