03-25-2008, 19:29 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 55
Member: 102467 Status: Offline Thanks Meter: 24 | warning do no try to use unlock v177 with infinity COM9 [VCP0] selected Action: unlock Device: V175,V176,V177 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.66 HW version: MOTOROLA_E58S LP ver: LP1_0166 Flex ver: FLEX_90_63_5B03 cpu id: 08B6 imei eeprom: 35223301045282 required SW version: 0.1.66 sp-locked: 22802. Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35223301045282_20080325-160701.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok error: errorcode#50: eeprom can't be erased Finished, time used: 55 sec Remove/Install battery now ! |
03-25-2008, 19:36 | #2 (permalink) | |
Member: 102467 Status: Offline Thanks Meter: 24 | Quote:
sp-locked: HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _48484848484848_20080325-193308.34E.bin Check Flash-2 Done Write... Writing: Eeprom eeprom write address adjusted error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: erase failed[48] at 05FE0000 error: Error during write: 05FE0000 Write Done Failed ! Finished, time used: 59 sec Remove/Install battery now ! | |
03-25-2008, 20:06 | #3 (permalink) |
Member: 102467 Status: Offline Thanks Meter: 24 | now the phone flashed with the good and very good box see the log COM9 selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: V175,V176,V177 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... rom code version: 0411 rom code version: 0411 initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.1.66 HW version: MOTOROLA_E58S LP ver: LP13_0166 Flex ver: FLEX_90_63_5B03 cpu id: 08B6 required SW version: 0.1.66 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20080325-194006.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 1404 sec Remove/Install battery now ! the phone still dead TO BE CONT |
03-25-2008, 20:15 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Nice to see so interesting story with quite nice thread name. Did you ever heard something about phone hardware faults ? Do you know something about flash write error reasons ? Did you ever tried to make "search" in this forum ? I think no, so there is no any reason to tell you that thousands Infinity-Box users unlocked V177 in seconds without any problems, that thousands Infinity-Box users repaired thair phones without any problems etc. etc. Anyway, my friendly advice for man who don't understand what he write here: double check cable, un-check "read imei from eeprom" and repeat flashing, check phone hardware. In case of any other stupid words like in thread name I'll close this discussion immediately. |
03-25-2008, 20:30 | #5 (permalink) | |
support and the historique of the phone in the good condition if u like to close this thread i think u like not the reality??? | |
Do you Try to unlock New T156 with Infinity ? -> Post log here !! | Faisal_Computer | Infinity-Box | 571 | 01-03-2011 09:10 |
Warning : Hacker Try to **** everybody using ChavalGSM Nickname on MSN and Sonork | UnlockBase.com | The Market Feed Back | 8 | 07-30-2009 21:46 |
L6:08.DO.when try to unlock it says phone not found | beneto | Smart-Clip | 8 | 02-10-2009 10:05 |
Worning do not try to unlock sagem cid185,186 mobiles with current setool2 version. | Miftahudin | SETool2 | 1 | 12-24-2008 23:10 |
DO NOT TRY TO UNLOCK S OR C 35 -V.20 OR HIGHER WITH ZeeSiemensG3.exe! PHONE WILL BE D | Joseph | x1x to x45/x50 | 2 | 10-23-2001 20:48 |
