vs6 security failure infinity team could you pls help me how to solve this problem SECURITY FAILURE VS6 phone was successfully unlock and reflash but still phone appear on screen SECURITY FAILURE? here are some log detailed: Phone must be in TEST-MODE: * + # + Power Connecting, wait... Phone found, wait... Connection Ok Unlocking... Imei: 357213003321740 SEC ver: 00.11Sg(0002) SW ver: NBG_LEOPARD_05.24SMARTI_SDB1SGOLDliteV1.1 MMI ver: Mmi:VS6-VQ26,Nov15200500:56:32 In progress [eeprom-01_357213003321740]... file saved: Backup_eeprom-01_357213003321740_2007-3-29_2-46-51.2DE.bin In progress [eeprom-02_357213003321740]... file saved: Backup_eeprom-02_357213003321740_2007-3-29_2-46-53.2DE.bin Found: Network Unlock code: 42708776 EXACTLY STEP-BY-STEP: 1. insert ANY sim-card into phone 2. switch-on phone 3. switch-off phone 4. switch-on phone, press 52824** 5. enter unlock code 6. switch-off phone Done Finished Testing COM1 at 115200... Device: VS6,VS7,SA7,MX7 Checking data, wait... Action: Flash write Boot... Press Power button now ! Checking... Boot answer: 02 Boot Done Set Baud... Set Baud Done Connecting... FLASH ID: 0089:880D Connecting Done Check free space... Flash chip supported In progress [eeprom-01]... file saved: Backup_eeprom-01_2007-3-29_0-59-21.2DE.bin In progress [eeprom-02]... file saved: Backup_eeprom-02_2007-3-29_0-59-22.2DE.bin Check free space Done Write... Reset... Done Writing: Firmware Verifying... Verify result: 0000 Err: probably zone write failed Writing: FFS-1/Customization Verifying... Done Writing: Language Pack Verifying... Verify result: 0000 Err: probably zone write failed Writing: Graphics Pack Verifying... Done Writing: FFS-2/File system Verifying... Done Writing: FFS-2/File system Verifying... Done Write Done Finished Remove/Install battery now ! Time used: 6348 sec |
Use good sim-card (that can be accepted by network). No need to use for tests bad sim cards, use only good sim cards ! |
all good simcard i insert it i think this is blacklisted unit. |
i tried putting vs6 into test its impossible to hgold all the keys plesae help? |
@TALLSAJ2 could you, please, explain the problem more detailed ? |
