01-25-2016, 18:15 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | vsun h9 firmware required Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4841473265040502A22A60A123 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265040502A22A60A123 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Vsun ProdName : H9 ProdModel : Vsun H9 Device : H9 AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.10 MODEM : BaseBand : MT6592_S00_MOLY_WR8_W1315_MD_WG_MP_V34_P3_1_wg_n Done! Elapsed: 00:00:22 Reconnect Power/Cable! Finish at : [23-01-2016 / 13:11:52] Start at : [23-01-2016 / 13:12:09] Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6592 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6592_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4841473265040502A22A60A123 DA Stat : v4.2 on BBID : 0x8A DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265040502A22A60A123 [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB INT RAM : 0x00020000 EXT RAM : 0x80000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Vsun ProdName : H9 ProdModel : Vsun H9 Device : H9 AndroidVer: 4.4.2 MTKxCPU : MT6592 MTKxPRJ : ALPS.KK1.MP1.V2.10 [Read Ok] : preloader_vsun92_wet_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : EBR2 [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [Read Ok] : fat.img [ScatCFG] : MT6592 / V1.1.2 / vsun92_wet_kk / EMMC FW Size : 1344 MiB |
08-28-2016, 15:38 | #9 (permalink) |
No Life Poster Join Date: May 2009 Location: Online
Member: 1024090 Status: Offline Thanks Meter: 1,175 | INSTALLATION AND UPDATE GUIDE (MTK) (H9 | H9 furious | DNA | Alpha+ | Capture | Aqua) 1. Download and install the driver in your computer and follow the instructions shown on the screen. 2. Download the UPDATED FIRMWARE of your device and extract the files. It will create an UNZIPPED UPDATED FIRMWARE folder. 3. Download the software tool and install the program. Follow the instruction as shown on the screen. Photo 1 4. Open the FLASH TOOL.exe as shown on the image above Photo 2 5. On the SMART PHONE FLASH TOOL screen, click DOWNLOAD TAB. 6. Click SCATTER-LOADING button and locate *MT6592_Android_Scatter.text in your UNZIPPED UPDATED FIRMWARE folder. *please take note that the version number may depend as per update Photo 3 7. Refer to the image above, click on firmware upgrade Photo 4 8. Before anything else, please make sure that your mobile is SWITCHED OFF, battery is CHARGED above 30%, and data cable is NOT CONNECTED to your PC and mobile. 9. Press DOWNLOAD on the phone flash tool window 10. CONNECT your data cable to your PC and then to your mobile. |
