10-24-2007, 21:48 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Moldova
Member: 106887 Status: Offline Thanks Meter: 48 | Motorola c121 dead!!!! unlocked ok, but after trying to flash the soft gived me a error, after that computer simply doesn't see the phone! just no reaction! what can i do? tried even to cut testpoint! noting... COM1 ready COM1 [Serial0] selected Action: unlock Device: C121 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[04]: general communication fault. Release Power button ! Connect Fail Finished, time used: 10 sec Remove/Install battery now ! COM1 [Serial0] selected Action: unlock Device: C121 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.75.E. HW version: _E88 imei otp: 353290016876609 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_353290016876609_20071021-150839.18E.bin imei eeprom: 353290016876609 Check Flash-2 Done Write... Write Done Finished, time used: 17 sec Remove/Install battery now ! Loading file v.01... C115_1.0.38_Main.18M.bin loaded Loading file v.01... C115_1.0.38_LP_T10_132.18P.bin loaded Loading file v.01... C115_1.0.38_Flex_15_132.18F.bin loaded COM1 [Serial0] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C121 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 1.0.75.E. HW version: _E88 imei otp: 353290016876609 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_353290016876609_20071021-151139.18E.bin imei eeprom: 353290016876609 Check Flash-2 Done Write... Writing: all flash areas error: write at 00002000: error: write at 00002000: error: write at 00002000: error: write at 00002000: FF error: write at 00002000: error: write at 00002000: error: write at 00002000: Write Done Failed ! Finished, time used: 53 sec Remove/Install battery now ! COM1 [Serial0] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: C121 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 00 error: boot failure[02]: 00 Release Power button ! Connect Fail Failed ! Finished, time used: 32 sec Remove/Install battery now ! |
Motorola C121 unlock help help | cecogsm | Ultima Box Light | 17 | 07-22-2007 08:33 |
Motorola C121 | faustus | Sell ur Old and Used Stuff | 0 | 05-10-2007 22:12 |
motorola c121 new cell phone unlock??? | Siemens man | Infinity-Box | 33 | 03-02-2007 13:21 |
Unlock Motorola C121 | hitibiti | Multi-Box | 4 | 02-11-2007 11:44 |
how to unlock new motorola c121???? | Siemens man | Motorola ODM | 7 | 01-13-2007 23:42 |
