01-25-2007, 07:41 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | w220 dead after flash results on flash 1. fon ok .... but no netwrk 2. fon ok ... netwrk ok... but menu icons invisible 3. pack error 4. fon dead now i m trying to flash it again but the fon is not booting... plz help |
01-25-2007, 07:50 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Your problem is not a problem with phone but problem with reading. As you know, so many people have not enough time to read this forum (just want to remind, I did not told "people are lazy", I told that "people have not enough time"). When you will have little bit more time you can make "seach" in this forum and I am sure you can find answers for your problem in 1 minute. Anyway, here you can see my advices (because you have not enough time to find answers by yoursef): 1. CHARGE BATTERY 2. use correct flash files, select files correctly by this manual: http://www.infinity-box.com/download...p?id_file=2743 |
01-30-2007, 07:07 | #5 (permalink) |
Junior Member Join Date: Jan 2007
Member: 442039 Status: Offline Thanks Meter: 0 | w220 error Hi@all I have a w220,too. i want to full flash the w220 with a t191 cable and mst 1.2.4 . now the phone dont start. what can i do? how can i unlock the phone just with an t191 cable, mst 1.2.4 or PcRedownload? Please say how to unlock. P.s. sorry for my bad english. |
01-30-2007, 10:13 | #6 (permalink) | |
all answers you can find here: www.infinity-box.com | |
02-04-2007, 15:00 | #9 (permalink) | |
Freak Poster Join Date: May 2006
Member: 281468 Status: Offline Thanks Meter: 24 | Quote:
Device: W220 Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: Flex Write: Language Pack Skip: FFS/File system Write: Images Write: Melody Skip: Eeprom Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... SW ver: 103A-000 HW ver: SCY-7- Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:886400010001 flash: Intel 28F640W18-T T 8Mb Write: Flex flash: Intel 28F640W18-T T 8Mb Write: Language Pack flash: Intel 28F640W18-T T 8Mb Write: Images flash: Intel 28F640W18-T T 8Mb Write: Melody flash: Intel 28F640W18-T T 8Mb Writing Done Finished, time used: 327 sec Remove/Install battery now ! hello mr infinithy i have problum with w220 i flashed the phone but it give me ann errer when i put sim card in the phone it give a massage of the (invalid telefone) what can i do to solve this problum i have writed the right flash file thanks in advance | |
02-04-2007, 18:33 | #10 (permalink) |
Member: 275631 Status: Offline Thanks Meter: 408 | here is the solution... to how to choose flash files http://www.infinity-box.com/download...p?id_file=2743 |
w220 (usa) dead after flash with infnity | zeerik | Infinity-Box | 1 | 03-16-2010 03:56 |
W220 dead after flashing. | Mr GsM | Infinity-Box | 5 | 03-24-2009 13:46 |
w220 dead after try flash.. | michel.tissier | Rocker Dongle (By Legija) | 4 | 02-15-2009 04:53 |
W220 DEAD after write first Flash | nser5 | Ultima Box Light | 0 | 09-14-2007 22:17 |
W220 dead after flashing. Help!! | cqln | Motorola P2k | 1 | 02-22-2007 21:58 |
