11-04-2007, 23:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 45
Member: 348590 Status: Offline Sonork: 100.108198 Thanks Meter: 200 | w220 NO FOUND UNLOCK Device: Motorola W220 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb version sw: 1220-000 version sw: SCA-7- Check flash Done Check parameters... reading Motorola W220_eeprom_calibration-1... file saved: backup_Motorola W220_eeprom_calibration-1_20071026-171758.6AE.bin Check parameters Done Check data... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data Done Writing... error: no locks present or unknown eeprom structure Writing Fail Finished, time used: 17 sec Remove/Install battery now ! |
11-04-2007, 23:45 | #2 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: Djazair
Member: 111121 Status: Offline Sonork: 100.99340 : CrKdz13 Thanks Meter: 487 | Quote:
11-05-2007, 00:09 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @mundomacu Dear Friend, Before write here big font message it's good idea to check support area and download latest updates: http:///vbb/showthread.php?t=463157 One more good idea: try to make "search" in this forum and for sure you will have an answer for your problem. If you unable to use "search" you must read this advice http:///vbb/showpo...15&postcount=2 and your problem will be solved in 15 seconds. |
11-06-2007, 14:24 | #4 (permalink) | |
Member: 348590 Status: Offline Sonork: 100.108198 Thanks Meter: 200 | Quote:
11-06-2007, 14:59 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You must download and use latest software from support area ! Also in case of any problems you must follow this advice: http:///vbb/showpo...15&postcount=2 Therad closed |
Unlock patch no found.. for 1112 ver 6,46 asic 11.. please need support this model | residentdenuevo | Cyclonebox | 9 | 05-21-2009 13:50 |
W220 no ring tone | rk19801 | Motorola Hardware Repair | 2 | 08-01-2008 09:39 |
W220 No White Screen After Flash | magixian | Ultima Box Light | 3 | 06-25-2008 18:31 |
No found Unlock File! phone dead | fofodaman | Seking Server | 2 | 11-24-2007 16:41 |
J100 no found in list smartmoto 2.38 for unlock!!! | mhrm1 | Smart-Clip | 4 | 11-22-2007 15:47 |
