02-18-2009, 09:35 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | W220 not going to connect i hav cell motorola W220 its not going to connect through jeck is thre any rx tx marked on pcb? kindly help me need picture for pcb with rx tx for motorola w220 the fault is that it is only showing menu icons not other in settings and other icons in the menu bar |
02-18-2009, 14:02 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @azeem781986 1. is it W220 from AT&T ? 2. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
02-19-2009, 10:55 | #4 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | no sir w220 local cell fone its unlocked not showing menu icons i hav perfect cable and also latest pinouts and each n every infinity module updated i hav done already 3 cell phnes i.e 1.W375 2.C261 3.C118 with this cable and i hav trouble while connecting this cell phone i hav already chked on multimeter it gives grnd and other two values for tx n rx but not going to connect i hv also uni cables by infinity team but not going to connect this phone that is y i askd for rx tx if threre r on pcb like chinese phones so that i can coonnect it easily this is my problem thanks in advance infinity is the best box and thanx for quick reply u always care for ur customers big big thanx |
02-19-2009, 12:04 | #5 (permalink) |
No Life Poster Join Date: Mar 2008 Location: infinity-box
Member: 720034 Status: Offline Thanks Meter: 213 | Hello, We have no pictures with Rx/Tx for W220 due to it was more than enough to use ordinary connector. What is the problem with connection exactly ? Post here operation log |
02-20-2009, 14:24 | #6 (permalink) |
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | sir actually my phones is not going to connect when box says press n hold power button it dosnt say anymore thing jst press n hold power button i swapped rx n tx but same thats y i think my phone jeck is faulted so thats y i asked about rx tx on pcb thanks |
02-20-2009, 14:48 | #7 (permalink) |
Member: 720034 Status: Offline Thanks Meter: 213 | Hello, if you are sure that your cable is good and phone connector is not damaged it may be a problem with latest w220 PCB type that is not supported yet. But if you think that it may be connector problem ou can try to find w220 service manual and check there is any test points exist for Rx/Tx at phone PCB. |
02-21-2009, 17:39 | #9 (permalink) | |
Member: 720034 Status: Offline Thanks Meter: 213 | Quote:
We will try to make support for KP170 ASAP. You can check news at www.infinity-box.com from time to time. | |
GT-M2510 pinout here, cable 100% phone not go to testmode so can UST-2 unlock or not? | bestin | UST Pro II | 10 | 10-15-2009 17:22 |
5200 connect with jaf but not able to connect with mxkey | rakesh15 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 09-13-2009 15:23 |
can not go to support area | janjaroen | UST Pro II | 3 | 03-17-2006 06:16 |
please help i can not go to the support | zulea912 | SonyEricsson (USB-Smart) | 1 | 02-15-2006 20:39 |
Box not going to test-mode anymore | UnlockBR | Astro Clip | 16 | 12-28-2005 13:22 |
