10-21-2007, 13:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2006 Location: moldova Age: 48
Member: 259209 Status: Offline Thanks Meter: 37 | w220 not unlocked Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb version sw: 1240-000 version sw: SCY-7- Check flash Done Check parameters... reading Motorola W220_eeprom_calibration-1... file saved: backup_Motorola W220_eeprom_calibration-1_20071021-153522.6AE.bin Check parameters Done Check data... Check data Done Writing... error: no locks present or unknown eeprom structure Writing Fail Finished, time used: 14 sec Remove/Install battery now ! |
10-21-2007, 13:59 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Are you sure that your phone is sp-locked ? if you are sure that phone has sp-lock but not user lock) try this: http://www.infinity-box.biz/download...dule_v1.07.rar |
10-22-2007, 05:17 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Moldova Age: 41
Member: 204045 Status: Offline Thanks Meter: 7 | COM30 [VCP0] selected Device: Motorola W220 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb version sw: 1240-000 version sw: SCY-7- Check flash Done Check parameters... reading Motorola W220_eeprom_calibration-1... file saved: backup_Motorola W220_eeprom_calibration-1_20071022-071617.6AE.bin Check parameters Done Check data... Check data Done Writing... error: no locks present or unknown eeprom structure Writing Fail Finished, time used: 9 sec Remove/Install battery now ! The same problem (with 1.07 version) BR |
11-01-2007, 20:44 | #8 (permalink) |
No Life Poster Join Date: Sep 2002 Location: allsiemens.com Age: 37
Member: 15925 Status: Offline Thanks Meter: 11 | I have allways problem with unlocking W220, if i push SP-UNLOCK button ,unlock doesn't work. But if i push first Repair and than unlock it working very fine. also if the phone was started second time |
01-09-2008, 10:48 | #12 (permalink) |
No Life Poster Join Date: May 2007 Location: Shoaib Electronics
Member: 515273 Status: Offline Sonork: 100.1573940 Thanks Meter: 339 | I unlock W220i to infinity with in seconds its work very well.I think its eeprom problem just try to repair it.Best of luck |
01-16-2008, 19:36 | #13 (permalink) | |
Junior Member Join Date: May 2006
Member: 285414 Status: Offline Thanks Meter: 0 | Cannot unlock W220 Quote:
COM25 [VCP0] selected Device: Motorola W220 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Any suggestion? | |
01-17-2008, 21:44 | #15 (permalink) |
Member: 285414 Status: Offline Thanks Meter: 0 | No, it is not. It's from Digitel (South American provider). W220 e2 HW.7 Imei: 3519.... The box (infinity slim plus) works perfect. I unlocked several LG without a problem. I tried the same procedure with the Motorola but had the problem mentioned above. |
my black berry 8100 is not unlock (Answered) | ravin j tejura | MXKEY Blackberry Flasher and Unlocker (by Alim Hape) | 11 | 04-08-2010 15:05 |
lg bl20 not unlocking | simlock | Z3X-Team Products | 1 | 03-29-2010 18:47 |
w220 NOT UNLOCK SWVer=1.112(OLD VERSION) | 936mw | Smart-Clip | 5 | 01-16-2008 11:26 |
w220 hungary pannon not unlocked | Siemens man | Infinity-Box | 5 | 12-20-2006 23:10 |
