Unlock Server
Old 08-11-2007, 09:29   #1 (permalink)
Member: 102129
W220 Pack Error - Won't Flash
I've got a W220 giving the pack error message.
I'm trying to flash it with all the files to restore it, but it won't flash. I power the phone on as requested at the on screen prompt, the phone turns on, coming up with the pack error message but it doesn't start to write.
Any suggestions?
Old 08-11-2007, 09:59   #2 (permalink)
Member: 220195
it's a cable problem
use Pana X60 cable
Old 08-11-2007, 10:00   #3 (permalink)
Member: 20069
Any suggestions?
hi m8
nothing to worry . u can easily fix it just login to support area n download from there "Flash Files/Language Pack description for Infinity-box" html file. in this file the infinity team has mentioned the exact table for each main+Languagepacks+Flex+images+Melody+Fs so just made ur choice n download them n flash ur fone will full charged battery n ur fone will be ok.
Best of Luck n Happy using Infinity box.
Infinity uSeR
Old 08-11-2007, 10:10   #4 (permalink)
Member: 148515
hello!
make sure that you using right com port, right cable.
maybe cable modification is needed to make it fit in phone properly.
picture how to cut rubber you can see selecting G50 phone and checking it's pinout picture number 2 and 3.
Old 08-11-2007, 12:24   #5 (permalink)
Member: 102129
It's not a cable/port issue, used it many times on W220/W375 and I can flash with UBL, but the UBL flashfiles don't seem to cure the pack error problem.
But Infinity will not flash.
Old 08-11-2007, 13:07   #6 (permalink)
Member: 102129
Now sorted, UBL must have kick started it.
Old 07-13-2008, 08:01   #7 (permalink)
Member: 767451
infinity team pls help what can i unlock zte 125225 ,a61 a36 pls help
Old 07-13-2008, 13:40   #8 (permalink)
InfinitySupport's Avatar
Member: 130995
@fidmdoe
Just run Infinity-Box Shell, select required model and see pinout, then connect cable to phone, go to software \"Service\" page and press \"unlock\" button.
Also you must read unlocking manuals from Infinity-Box support area \"manual\" folder.
Good luck !
w220 pack error ::. zine .:: Ultima Box Light 0 11-11-2007 15:24
w220 pack error sanjeewa57 Infinity-Box 5 07-20-2007 23:01
Pack error W220 seydisaliou Infinity-Box 4 03-12-2007 11:30
w220 after flash PACK ERROR stefan_162 Infinity-Box 4 01-16-2007 21:25
6600,cbus error.won't flash aldrex Twisterflasher 1 07-11-2004 11:20
Page generated in 0.59725 seconds with 11 queries
