Old 03-12-2008, 06:09   #1 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 782
w220 sca 7 flashing problem...
kindly check my log sir...
COM4 [Serial2] selected
Device: Motorola W220
"advanced chip detection" active
Action: flash write
"smart write" active
Write: Firmware
Write: Flex
Write: Language Pack
Skip: FFS/File system
Write: Images
Write: Melody
Skip: Eeprom
Checking data, wait...
Boot...
Press Power button now !
loading...
Boot Done
Check connection...
Check connection Done
Set baud...
Set baud Done
Check flash...
flash: 208810FFFFFFFF:20881000000000
flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb
version sw: 1220-000
version sw: SCA-7-
Check flash Done
Check parameters...
reading Motorola W220_eeprom_calibration-1...
file saved: backup_Motorola W220_eeprom_calibration-1_20080312-130452.6AE.bin
Check parameters Done
Check data...
warning: Probably wrong model selected,
Do you want to continue ?
model selection confirmed by user
Check data Done
Writing...
Area: Firmware
Write: Firmware
error: no any expected answer
error: flash write error: 00000000:00002000
Writing Fail
Finished, time used: 50 sec
Remove/Install battery now !
i want to flash it with scy 7 flash file.. but can do it... is there a way so that i can convert this phone??
thanks!!
Old 03-12-2008, 10:21   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Flash write process not depends on selected flash files.
Please, charge battery completely and try again.
What was original phone state ? Is it was good phone or damaged ?
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 rafik2533 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 04-04-2010 20:38
i flashed nokia 7610s rm-354 version 7.23 problem restart but after flash 33872 Nokia Base Band 5 ( BB-5 ) 3 01-12-2010 09:15
myx-7 flashing problem sonetek SMTi 0 04-17-2008 17:36
w220 flashing problem sonetek Infinity-Box 2 06-07-2007 11:19
W220 flashes problem roberts Infinity-Box 4 12-11-2006 22:54
Page generated in 0.16948 seconds with 10 queries
