w220 unlock eror w220 unlock eror what the problem ???? COM3 [VCP1] selected module v1.38 Device: Motorola-W220 "advanced chip detection" active Action: unlock Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 89886400010001:89886400000000 flash: Intel Intel std [def 007Fx010000 0008x002000] 8Mb software version: 107A-000 software version: SCY-7- Check hardware done Read data ... reading Motorola-W220_eeprom_calibration-1... file saved: C:\Documents and Settings\Beyazgül Teknoloji\Desktop\Motorola-W220_eeprom_calibration-1_20100309-164035.6AE.bin Read data done Check data ... error: not locked or unknown eeprom Check data done Write ... .error: required data not found or unknown eeprom structure Write fail error: operation failed Finished, time used: 29 sec Remove/Install battery now ! |
What is the problem with phone exactly ? What you see at phone LCD ? :confused: br. rajesh ch. |
@uzmantel 1. make eeprom backup for emergency case 2. flash phone with any repair eeprom file from support area 3. make "Repair" operation from software "Service" page |
Add eeprom strong here Thank you in advance |
1. make eeprom backup for emergency case 2. flash phone with any "repair eeprom" file from support area 3. make "Repair" operation from software "Service" page |
Yellowbos thanx bro problem sloved method servise/Reset settings. format ffs |
