w220 - w375 can't connect i have w220 and w375 i can't connect by any way i try com cable and usb even pin finder and some thing strange when i try user code and phone should to be on connected and phone code 0000 both phones is brand new cable and phone soket clean and already opened the phone and rechek the soket what wrong code be ? |
any answer from infinty team ? |
i am very wonder why no such answer maybe coz my post don't give chanse to say clean the soket. chek cable. change pc ? |
reduce the baud rate and try again |
already try all avalible baudrate and all connaction method i have noticed that w220 phone code working while phone is on |
and me i have problem like this in w 375 pls help any user cant boot for any cables pls sir |
@fidmdoe What is the problem exactly with w375 connection ? |
i tr y many times to unlock this pc with x60 cable but can,t boot pls help sir. and what about w 230/ w181 /150i pls help |
Hello, Please, post here operation log so we will be able to check what is wrong. |
W220 flashed using infinity and have warning software not same as from unit but i still flashed it and now dead and not connecting.Any tips how to revive this unit? |
COM1 [Serial2] selected module v1.30 Device: Motorola-W220 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb software version: 235C-000 software version: SCU-9- Check hardware done Read data ... reading Motorola-W220_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20090129-204345.6AE.bin reading Motorola-W220_ffs... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_ffs_20090129-204543.6AE.bin Read data done Check data ... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data done Write ... Area: Firmware flash: 208810FFFFFFFF:20881000000000 Write: Firmware Write done Finished, time used: 640 sec Remove/Install battery now ! |
@fretburner Phone can not be dead permanently after flashing with files from support area. Charge battery and try to flash phone again with more high version files set (main + lp + images + melody + flex). @denisirias I don't think that phone can not be connected due to wrong firmware, It may be that phone can not power-on but phone should have ability to be flashed. |
