08-07-2008, 23:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 39
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | w220 - w375 can't connect i can't connect by any way i try com cable and usb even pin finder and some thing strange when i try user code and phone should to be on connected and phone code 0000 both phones is brand new cable and phone soket clean and already opened the phone and rechek the soket what wrong code be ? |
01-30-2009, 00:02 | #10 (permalink) |
No Life Poster Join Date: Dec 2003 Location: philippines
Member: 45571 Status: Offline Thanks Meter: 45 | W220 flashed using infinity and have warning software not same as from unit but i still flashed it and now dead and not connecting.Any tips how to revive this unit? |
01-30-2009, 00:27 | #11 (permalink) |
Member: 45571 Status: Offline Thanks Meter: 45 | COM1 [Serial2] selected module v1.30 Device: Motorola-W220 "advanced chip detection" active Action: flash write "smart write" active Write: Firmware Skip: Flex Skip: Language Pack Skip: FFS/File system Skip: Images Skip: Melody Skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! loading... Boot done Check connection ... Check connection done Set baud ... 115200 Set baud done Check hardware ... flash: 208810FFFFFFFF:20881000000000 flash: ST Intel std [def 007Fx010000 0008x002000] 8Mb software version: 235C-000 software version: SCU-9- Check hardware done Read data ... reading Motorola-W220_eeprom_calibration-1... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_eeprom_calibration-1_20090129-204345.6AE.bin reading Motorola-W220_ffs... file saved: C:\Program Files\InfinityBox\HModule\Motorola-W220_ffs_20090129-204543.6AE.bin Read data done Check data ... warning: Probably wrong model selected, Do you want to continue ? model selection confirmed by user Check data done Write ... Area: Firmware flash: 208810FFFFFFFF:20881000000000 Write: Firmware Write done Finished, time used: 640 sec Remove/Install battery now ! |
01-30-2009, 02:56 | #12 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | bad news for you I don't know if you are from Nicaragua and that phones are from claro let me tell you what problem is claro or personal in south America is the famous tracfone now this companies are using k3 firmware that allow you to connect the phones to any box |
01-30-2009, 05:28 | #13 (permalink) | |
Member: 309299 Status: Offline Thanks Meter: 259 | Quote:
01-30-2009, 09:52 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @fretburner Phone can not be dead permanently after flashing with files from support area. Charge battery and try to flash phone again with more high version files set (main + lp + images + melody + flex). @denisirias I don't think that phone can not be connected due to wrong firmware, It may be that phone can not power-on but phone should have ability to be flashed. |
01-31-2009, 00:59 | #15 (permalink) | |
can't connect w220 | market.killer | Infinity-Box | 7 | 06-18-2008 16:10 |
Motorola W220, SWVer=1.370 can't connect, unlock | serjer | Smart-Clip | 2 | 05-06-2008 12:25 |
W375 wont connect to PC? | CharlyAR | Motorola ODM | 6 | 11-19-2007 13:54 |
@GSM_Support - SmartClip will be support W220, W375 & etc? | fingusio | Smart-Clip | 5 | 02-19-2007 21:22 |
