10-29-2007, 11:20 | #38 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. you must buy Infinity-Box, see www.infinity-box.com or www.infinity-box.biz 2. you must read this thread from begin to see detailed instruction |
11-09-2007, 19:58 | #45 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Nigeria, Oyo state Age: 48
Member: 180091 Status: Offline Thanks Meter: 62 | his solution is superb.i tried it and is 100% okay. here is the log for flashing and unlocking respectively. COM17 [VCP0] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 6.9.75 HW version: MOTOROLA_H80S LP ver: Flex ver: FLEX_A0_00I cpu id: 08B6 imei eeprom: 35451301165999 required SW version: 0.0.62 Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35451301165999_20071109-182811.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 527 sec Remove/Install battery now ! unlocking COM17 [VCP0] selected Action: unlock Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 460800 Set Baud Done Check Flash-1... SW version: 0.0.80 HW version: MOTOROLA_H80S LP ver: 0080_A06 Flex ver: FLEX_A4_002 cpu id: 08B6 imei eeprom: 35451301165999 required SW version: 0.0.80 user confirmed unlock for non-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: backup_eeprom_calibration_35451301165999_20071109-184041.34E.bin unlock step-1 Ok unlock step-2 Ok unlock step-3 Ok unlock step-4 Ok unlock step-5 Ok finished Ok Finished, time used: 37 sec Remove/Install battery now ! keep the good work moving. Adebam |
W370 Tracfone Unlock / Flash | bigmac1204 | Scout | 9 | 07-14-2010 07:47 |
>> T349 successfully unlock << | jhepoy_org | UST Pro II | 7 | 09-02-2009 08:14 |
W370 tracfone unlock succes using smart-clip | maxieboy | Smart-Clip | 10 | 09-05-2008 07:10 |
W370 TracFone Unlock Success | Orange_Dominica | Smart-Clip | 12 | 08-12-2008 12:34 |
problem unlocking w370 tracfone | wakuwaku | Smart-Clip | 7 | 08-04-2008 10:06 |
