12-12-2007, 07:42 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I don't understand what is real phone history. What you tried to do with phone ? Did you tried to make unlock ? Did you tried to make flash ? Explain the problem so detailed as possible. Please, write in small letters because I will be unable to answer in questions written in so big font. |
12-12-2007, 08:03 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @T0T0 @MaHmUt1982 probably you both forget that Infinity-Box can unlock W375 very good and also you both forget that you are inside Infinity-Box support forum. Thank you for respect to Infinty-Bx team ! |
01-10-2008, 04:51 | #5 (permalink) |
No Life Poster Join Date: Apr 2003
Member: 26692 Status: Offline Thanks Meter: 51 | it happents to me too.phone is net 10.afther flashed say phone hacked. COM125 ready COM125 [Serial2] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 6.9.75 HW version: MOTOROLA_H80S LP ver: Flex ver: FLEX_A7_002 cpu id: 08B6 imei eeprom: 35830801008590 required SW version: 6.9.75 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_35830801008590_20080109-193319.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Language Pack Writing: Flex Write Done Finished, time used: 275 sec Remove/Install battery now ! Loading file v.02... backup_eeprom_calibration_35830801008590_20080109-193319.34E.bin loaded COM125 [Serial2] selected "smart write" active Action: flash Skip: Firmware Skip: Language Pack Skip: Flex Write: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete error: no synchronization ack received error: final boot phase failed Release Power button ! Connect Fail Failed ! Finished, time used: 39 sec Remove/Install battery now ! COM125 [Serial2] selected error: can't open COM125 Finished, time used: 3 sec Remove/Install battery now ! error: can't open COM125 COM125 [Serial2] selected error: can't open COM125 Finished, time used: 6 sec Remove/Install battery now ! COM1 ready COM1 [Serial0] selected "smart write" active Action: flash Skip: Firmware Skip: Language Pack Skip: Flex Write: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... Release Power button ! Connect Fail Finished, time used: 16 sec Remove/Install battery now ! COM1 [Serial0] selected "smart write" active Action: flash Skip: Firmware Skip: Language Pack Skip: Flex Write: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 error: can't set baud rate[0001] error: can't work at this speed. Use slow speed ! Set Baud Fail Finished, time used: 12 sec Remove/Install battery now ! COM1 [Serial0] selected "smart write" active Action: flash Skip: Firmware Skip: Language Pack Skip: Flex Write: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.64 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_AX_003 cpu id: 08B6 imei eeprom: 35830801008590 required SW version: 0.0.64 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_35830801008590_20080109-193319.34E.bin Check Flash-2 Done Write... Writing: Eeprom Write Done Finished, time used: 37 sec Remove/Install battery now ! COM1 [Serial0] selected "smart write" active Action: flash Skip: Firmware Skip: Language Pack Skip: Flex Write: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.64 HW version: MOTOROLA_H80S LP ver: 0062_003 Flex ver: FLEX_AX_003 cpu id: 08B6 imei eeprom: 35830801008590 required SW version: 0.0.64 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Archivos de programa\InfinityBox\Moto01\backup_eeprom_calibrat ion_35830801008590_20080109-193319.34E.bin Check Flash-2 Done Write... Writing: Eeprom Write Done Finished, time used: 37 sec Remove/Install battery now ! |
01-10-2008, 12:02 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @PILONCILLO What was the reason to write eeprom ? It's good idea to think before make something, at least ask advice before make something. Restore original eeprom file and press "sp-unlock" button. |
W375 Phone is hacked :2 100% repair | Bappppy | Infinity-Box | 4 | 06-25-2011 11:02 |
Motorola w375 phone is hack.... | rk19801 | Infinity-Box | 5 | 07-03-2009 16:00 |
w375 phone is hack | trio1 | Infinity-Box | 3 | 05-29-2008 08:58 |
W375 Phone is Hacked!!!!!!! | Wesleyraff | Infinity-Box | 6 | 07-13-2007 11:07 |
W375 Phone is hacked... | samusprime | IQ-Box | 2 | 07-07-2007 03:45 |
