01-10-2007, 11:05 | #1 (permalink) |
Major Poster Join Date: Jan 2006 Age: 68
Member: 217064 Status: Offline Thanks Meter: 2 | W375 Problem COM8 selected "smart write" active Action: flash Write: Firmware Skip: Flex Skip: Language Pack Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... Err: incorrect certificate Release Power button ! Connect Fail Finished, time used: 7 sec Remove/Install battery now ! |
01-10-2007, 11:45 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | what is phone sw version ? #02#* pls, write all info from LCD what is the reason that you want to upgrade only firmware w/o LP ? Do you understand that this action can cause little bit not so good working phone ? |
01-10-2007, 13:14 | #3 (permalink) |
Member: 217064 Status: Offline Thanks Meter: 2 | It's ok found the problem is was a cable issue. I have flash the W375 with firmware and LP as you requested. Now the phone does not turn on. (See below) COM8 selected "smart write" active Action: flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 921600 Set Baud Done Check Flash-1... SW version: 0.0.62 HW version: MOTOROLA_H80S LP ver: 0062_001 Flex ver: FLEX_AV_006 cpu id: 08B6 imei eeprom: *************** SW ver: 0.0.54 Check Flash-1 Done Check Flash-2... Check Flash-2 Done Write... Writing: Firmware Writing: Flex Writing: Language Pack Write Done Finished, time used: 387 sec Remove/Install battery now ! |
01-10-2007, 14:06 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | To be more clear: I did not requested you to write firmware + LP, I just asked you to tell me phone firmware version. what to do: 1. charge battery 2. press and hold phone power button for some time |
01-12-2007, 22:44 | #5 (permalink) |
Freak Poster Join Date: May 2004 Location: Algeria Age: 53
Member: 66566 Status: Offline Thanks Meter: 43 | I also going to flash my w375 to decustomize it and give result ========== SW Version 001C0062647277091000 Who : sw_cm Time: Tue Oct 31 11:36:40 2006 SW Ver: SW_W375_0.0.62.K2 Customer: Motorola FLASH: N/A Version Info. Code.90.01 Boot.90.05 FMGR.90.64 Flex_W375_BS_002 LangPack: LP_W375_0062_001 Chip Ver X ... .. . W_Dog:ON DSC:flex OFF Phone:security E+ Ver: EAGLEPLUS V1.2.4.1 p158871657 OTP is locked ======================== |
01-12-2007, 23:27 | #7 (permalink) |
Member: 66566 Status: Offline Thanks Meter: 43 | Process done, phone is alive Using T191 cable and W375_0[1].0.62_Main_H80S_1164336564.34M.bin from support ==================== COM1 selected "smart write" active Action: flash Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Device: W375 Checking data, wait... Connect... Press and HOLD Power button... Connecting... initial boot phase complete Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: 0.0.62 HW version: MOTOROLA_H80S LP ver: 0062_001 Flex ver: FLEX_BS_002 cpu id: 08B6 imei eeprom: xxxxxxxxxxxxxxx SW ver: 0.0.62 sp-locked: 20801. You want to write Flex in sp-locked[20801.] phone, Make this only when you understand what you want to do ! Are you sure you want to continue ? user confirmed Flex write operation in sp-locked phone Check Flash-1 Done Check Flash-2... reading ... file saved: Backup_eeprom_calibration_xxxxxxxxxxxxxxx_2007-1-12_22-52-33.34E.bin Check Flash-2 Done Write... Writing: Firmware Writing: Flex Writing: Language Pack Write Done Finished, time used: 1928 sec Remove/Install battery now ! ============================= Result next infos (#02#): Exactly same ! why ? and how can I have original motorola software (I mean without Virgin Mobile menu)? B.R |
01-12-2007, 23:31 | #8 (permalink) | |
Member: 66566 Status: Offline Thanks Meter: 43 | Quote:
It's always a good experience for me The phone is working nice, but with the same menu | |
01-13-2007, 01:00 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Phone has the same customization state after flashing because you have used the same files that already was inside phone (you just flashed the same old firmware, lp, flex). |
w375 problem | keeran | Smart-Clip | 5 | 01-08-2009 13:54 |
w375 problem | harshpahwa | Motorola Hardware Repair | 1 | 07-26-2008 07:06 |
w375 problem please help | chauhn21 | Smart-Clip | 8 | 06-20-2008 00:27 |
w375 problem after unlocking with infinity | farry | Infinity-Box | 2 | 09-01-2007 14:39 |
w375 problem | zipzap_kill | Infinity-Box | 3 | 08-29-2007 17:43 |
