Old 05-29-2007, 03:08   #1 (permalink)
ticoichip's Avatar
Member: 194302
Thanks Meter: 32
Thumbs up w800i cant call after flash !
I have Sonic W800i
Chip MT6219
pinout :
1: Gnd
2: Tx
3: Rx
4: USB D-
5: USB D+
6: +Vcc
7: +Vcc
8:
Phone dead before.I try to formAT---> phone alive but cant make a call.(phone has full signal).
Try to flash another flash files.But it's same problem.
Anybdy has idea?
Thanks
Old 05-29-2007, 09:51   #2 (permalink)
Member: 148515
Thanks Meter: 10,951
hello!
if format ffs did not help- flashing is usless in most cases.
this must be some hardware fault
Old 05-30-2007, 02:52   #3 (permalink)
ticoichip's Avatar
Member: 194302
Thanks Meter: 32
How about epprom? What for?
My phone's woking before. It auto go down, I try format-->it's ok but no signal Try flash another version-->same problem.
Old 05-30-2007, 22:15   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 33,230
@ticoichip
it will be good if you will know your phone status befor operation. In your first message phone was "Phone dead before", but in 2nd message "My phone's woking before". Where is the truth ?
Also, if phone has low signal or no signal you must check phone hardware !!! and maybe need to write other firmware (try different files).
You can use repair eeprom files, but there is very small chance that eepom file helps you to repair low network signal level.
Old 05-31-2007, 00:56   #5 (permalink)
ticoichip's Avatar
Member: 194302
Thanks Meter: 32
sir !
I mean.My phone can call before dead.
Sometimes i think our file have corroupt. i sent email. Did you check it?
Again, thank for your reply,i try to repair and post my result.
You can check ur email. I sent you.
Thanks
nokia n95 dual sim cant answer call after flashing obioha Infinity-Box 1 05-23-2008 12:44
w800i white screen...after flash.. help! davidliu21 Cruiser Suite 2 06-28-2006 13:03
W800i Configuration error...After Flash, Help? citifone Cruiser Suite 10 11-28-2005 08:54
Cant make calls after flash sidandrose HWK 4 11-09-2005 01:13
W800i no signal after flashing flash Cruiser Suite 4 09-25-2005 13:32
Page generated in 0.23508 seconds with 8 queries
