Old 12-29-2007, 08:43   #1 (permalink)
Member: 321534
Thanks Meter: 18
want infinity support help for chines phone
hello,
i want help about this phone, model no-s808 or zt-8900 both r completly same hardware. when power on the phone, it on and show processing 10% to 100% on its display and hang .when i try to format it on infinity it says new firmware detected. firmware is (M600Z_W10_PCB04_GPRS_MT6228_SO2.00_0.BIN_E194010A ) and phone hardware is PROCESSOR--MT-6228T RAM IS - HYNIX -HY5S5B6GL OTHER SECONDRY RAM IS HYNIX-KOR-HY 27UFO81G2A this ram is side lag ram. system connector 12 pins and (1-gnd. 6-rx . 7-tx) wide display, touch screen, dual camera memory slot micro sd type, single sim, on front view slider keypad.
. so please give me your support as soon as possible. e-mail -[email protected]
thanks......
Old 12-29-2007, 08:51   #2 (permalink)
stan1comm's Avatar
Member: 609952
Sonork: 100.1574492
Thanks Meter: 154
read the flash flash file and send to a infinty team they will add in very soon
www.stan1comm.com
Old 12-29-2007, 08:53   #3 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
No one can help u untill u help yourself.
now question is how u help yourself. so follow the steps.
1) Read the Chinese Miracle Help & Manual as well as read in The forum by searching.
2) Open Pinout Folder in InfinityBox folder and try to find the same picture as your fone have or atleast same pinouts.
3) Try to find same Firmware on the support if u can't find first make the Backup of full flash.
4) No format the fone or try to repair security area when u have backup even if it saying unkown hardware even then format it.
After trying this post your result here.
Take Care
ENJOY
Old 12-29-2007, 09:20   #4 (permalink)
Member: 321534
Thanks Meter: 18
Red face for chines help
thanks for reply
i send firmware and total detail of phones whith image,but fail to get satisfaction result from infi- supp. now infi can not able to read full flash , it only can read firmware operation. thats a my big problem and also bad luck. i have this type of tree mobile whith same fault. it is perfect that infi has no solution and support of this type of cpu based phone yet, because i try to find this type of firmware on support area but not found so i thik it. firmware -M600Z_W10_PCB04_GPRS_MT6228_SO2.00_0.BIN_E194010A
Old 12-29-2007, 10:22   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
@bharatg
Here is detailed step-by-step instruction how to repair your phone. You must read FAQ before you ask questions.
http:///vbb/showthread.php?t=476373
If you want to get more info and solution for your probelm you must read text in software Log window, read phone firmware and send
send "backup_flash..." and "backup_system_log..." files to [email protected] for more research.
small addition: you must check support area before write here that we don't have flash files for your phone !!!
Similar firmware M600Z_W10_PCB04_GPRS_MT6228_S02.00_0__En_Cn file was uploaded in support area in September of 2007 !
pls infinity support help me for 6300 flashfile balbal Infinity-Box 3 08-05-2009 22:19
Here is two bin files for Chines phones!!! .::skybird::. Chinese Models & Cloned Phones 0 09-06-2008 07:56
need help with chines phone armany99 Infinity-Box 12 06-23-2008 22:25
for infinity-support help EASYTECH Infinity-Box 8 04-06-2008 06:06
DISTRIBUTORS & RESELLERS Help Wanted - Recovering Support Access for box SN:45xxx matyjasz UFS2 + UFS3-Tornadoflasher 1 06-07-2006 21:32
Page generated in 0.39379 seconds with 9 queries
