Old 05-01-2009, 17:24   #1 (permalink)
.::Dr.Gsm::.'s Avatar
Member: 238374
Sonork: 100.1597005
Thanks Meter: 1,084
want nokia 5330 china pinout
here is set pic
nokia 5330 express music
i want this set pinouts
Old 05-01-2009, 18:16   #2 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
check this link: "Chinese Miracle" pinouts and FAQ (Frequently Asked Questions)
Old 05-03-2009, 00:11   #3 (permalink)
Member: 148515
Thanks Meter: 15,713
hello!
start from looking to infinity pinout folder.
continue with search option in this forum.
if both places will give zero result- post connector type
Old 05-03-2009, 13:47   #4 (permalink)
Member: 238374
Sonork: 100.1597005
Thanks Meter: 1,084
but i can't find any way thx for reply
Old 05-05-2009, 17:53   #5 (permalink)
Member: 148515
hello!
and what is connector type?
Old 05-18-2009, 05:32   #6 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 714
12 pin jack 6x6
{ahmadge}
Old 05-18-2009, 19:46   #7 (permalink)
Member: 148515
Originally Posted by ahmadge View Post
12 pin jack 2x6
{ahmadge}
hello!
lets start from checking what CPU it is based.
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software.
if it does supported- i can teach you how to find pinout by measuring voltage on phone system connector pins
Old 05-19-2009, 06:50   #8 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 714
ok
cpu mtk6225a
{ahmadge}
Old 05-19-2009, 21:47   #9 (permalink)
Member: 148515
hello!
if you dont have pinfinder - i can teach you how to find pinout by measuring voltage on system connector pins
Old 06-09-2009, 12:33   #10 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
hello!
Sir kindly teach how to find rx tx by mesuring voltage on system connector pins
Old 06-11-2009, 21:46   #11 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
Old 10-31-2009, 09:04   #12 (permalink)
gsm-world's Avatar
Member: 582790
Thanks Meter: 378
here is diagram .tested by me.
http://forum.gsmhosting.com/vbb/show...15#post4987215
The Following User Says Thank You to gsm-world For This Useful Post:
China Nokia 5330 Firmware required Munir Memon Infinity-Box 7 01-14-2010 19:51
5330 china express music pinout gsmsmile Infinity-Box 0 11-15-2009 10:16
nokia 5330 pinout needed ahmadge Chinese Models & Cloned Phones 1 10-31-2009 09:02
Plise Help Pinout Nokia N78 China Pin 20 alirag Chinese Models & Cloned Phones 0 09-07-2007 01:16
Page generated in 0.34874 seconds with 8 queries
