07-20-2015, 09:01 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | want to unlock Huawei G7105 here is full flash backup BYD53_10A_PCB01_GPRS_MT6253_S00.W5_1ES01V01_02.BIN _FLNPF38F3050M0Y3DH__fullflash_20150720-122841.B0M.bin.7z read log: Code: COM6 [ProlificSerial2] selected module v4.47 Device: _Autodetect MT6250-6253 etc. Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A04:8A00 status: FF bbchip bl ver: FE NOR flash id[0093]: 0089:890300000000 [INTEL] PF38F30xxM0x1xx chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00000108 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6253:8A04:8A00 ram test (40000000)... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... error:0BF9:S_DA_HANDSET_SEC_INFO_NOT_FOUND detect custom parameters... error:0401:S_CUST_PARA_NOT_SUPPORTED detect project-id... project-id: W5.1ES01V01.02 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: BYD53_10A_PCB01_GPRS_MT6253_S00.W5_1ES01V01_02.BIN_FLNPF38F3050M0Y3DH project-id: W5.1ES01V01.02, 00000000 code offset: 00000000 ffs offset/size [02]: 00D80000/00280000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v4.47, database date: 27.03.2014): BYD53_10A_PCB01_GPRS_MT6253_S00.W5_1ES01V01_02.BIN_FLNPF38F3050M0Y3DH This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\InfinityBox\MModule\BYD53_10A_PCB01_GPRS_MT6253_S00.W5_1ES01V01_02.BIN_FLNPF38F3050M0Y3DH__fullflash_20150720-122841.B0M.bin Disconnect... done Finished, time used: 27 min 49 sec Remove/Install battery now ! imei: 867874001923473 cid: QISG7105 note: i calculated 3 time codes and entered but not work now i have only 1 try remaining. |
07-20-2015, 09:20 | #2 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | can i do operation direct unlock for tihs model? if yes then plz guide me a little ........how? i am newer therefore i ask a little Q. |
