04-25-2013, 10:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Uttar Pradesh India
Member: 656277 Status: Offline Thanks Meter: 187 | want to unlock samsung b119 mts here is info. about it HARDWARE : SCNNZ317 COMPILE : Nov 26 2009 (16:55:52) REALEASE : Mar 29 2007 (20:00:00) SW Version : QSC6010 SCNNZ 3170 _ --------------------------------------------------------- Phonce code : 0000 Finished, time used: 3 sec when i click on unlock show this error SCNNZ317Nov 26 2009 SCNNZ317Nov 26 2009 SAMSUNG B119 CK26 version selected.. downloading mode... Wait reconnecting port... detecting port port ok.. dm mode... downloading mode failed... Finished, time used: 10 sec plz help m |
04-25-2013, 11:40 | #2 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | Instruction to Unlock samsung b119 new DC-26 version and B159 DE-26 version in force mode . 1)User must have Samsung E-210 cabel usb+rj45 ( 2 in 1 cable ) because phone is unlocked in 2 steps 2) Press 9+power together in dispaly of phone it should show you (qsc boot download) 3) User Must see version in phone screen in boot mode It will shows version in detail in screen of phone 4) then select sacumdm IN COMPORT SETTING OF INFINITY software 5)Select model from list the version which show in dispaly for eg :in dispay it shows main :ck26 16:55:42 select b119 ck26 boot and press sp unlock and wait for phone to Restart 6) Rest all operation same as normal unlcok . 7) After phone Restart user need to disconnect phone and use any uni box or infinity box put rj-45 cable in box and connect phone using rj-45 8)Now select samsung Sch-B309,b319,b619 model from list and press spunlock 9) If sp unlock success then phone should be unlocked . If it is not success then User need to put this code 47*869#123580 , a menu will appear on the phone screen select the option "portmap" then select hfk after select hfk , select uart1 and save it . Restart phone and try spunlock again from Step 2 note VERY IMPORTANT :All sp unlock operation should be without sim and must check version carefully for force mode wbr tejaram |
The Following User Says Thank You to .::TEJARAM::. For This Useful Post: |
04-26-2013, 04:49 | #3 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 704971 Status: Offline Thanks Meter: 4 | Dear netish tej ram post will hehp u and some other steps also will help u what i do is just connect phone with prolific usb cable with e210 rj 45 cable.select com do unlock.phone will in downlod mode.screen will go blue with all info about phone.now u will see the com selection in infinity changes so u have to select right com again then select right boot and do force unlock .all will ok |
03-27-2015, 08:36 | #5 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Raiganj Age: 37
Member: 1175794 Status: Offline Thanks Meter: 186 | simple sollution for all cdma. first read nv item by cdma workshop, then write unlock dump for that mobile from xxxxxx server. (of couse with xxxxxx) last restore the nv file by cdma workshop. HOLA............. Last edited by YellowBoss; 03-29-2015 at 12:37. Reason: advertizing removed |
