01-25-2010, 12:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | warning: can't read software version, probably unknown firmware COM3 [VCP0] selected module v3.07 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HUSCKY_S16_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_230_YYMMDD_CAM_MCPMCP_O__fullflash_2 0100125-154131.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2803:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware 67 byte(s) read connection lost error: operation failed ! Finished, time used: 9 sec Remove/Install battery now ! Read Flash File http://rs338.rapidshare.com/files/34...0100125-154131 |
01-25-2010, 20:12 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, try to use this new software: http://www.infinity-box.com/download...e_v3.08_v2.rar Waiting for your results. |
01-26-2010, 10:41 | #4 (permalink) | |
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | Quote:
COM3 [VCP1] selected module v3.08 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HUSCKY_S16_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_230_YYMMDD_CAM_MCPMCP_O__fullflash_2 0100125-154131.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:2803:000E status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware 67 byte(s) read connection lost error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! | |
01-27-2010, 20:53 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! have you modified your main infinity box to deliver more power? for this you must remove and shortcut diode inside of Infinity box (not pinfinder) this diode is limiting output voltage from available 5v to 4,3. this is too less for correct test mode for some phones. i would advice you to do modification. this procedure is detailed explaned in Pinfinder User Manual, Trubleshooting section |
Calibrate touch did'nt work-can't read sw version! | Riteshgpt60 | Infinity-Box | 2 | 01-04-2010 15:05 |
Pantech G310C Unknown firmware version | aarons6 | VygisToolbox | 12 | 08-17-2009 17:27 |
Can't read software version | i_am_in | Infinity-Box | 2 | 08-06-2008 16:48 |
Nckia E68 !!! Unknown Firmware version !!! backup | osom | Chinese Cocktail | 1 | 02-27-2008 03:55 |
How to read software version to a locked a1200? | emicabher | Motorola P2k | 0 | 10-13-2007 20:56 |
