03-25-2008, 18:59 | #1 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 219015 Status: Offline Thanks Meter: 42 | Voxtel BD50 dead after flash this log from my operation... Device: Voxtel BD50 Checking data, wait... Action: read flash Boot... Press and HOLD Power button now ! Connecting, wait... Release Power button now ! Boot Done Set baud... 460800 Set baud Done Check Flash... Check Flash Done Check space... Reading [flash_part_1_of_2]... file saved: backup_flash_part_1_of_2_20080322-165200.40X.bin Flash ID1: 00B00011 Reading [flash_part_2_of_2]... file saved: backup_flash_part_2_of_2_20080322-165800.40X.bin Flash ID2: 00B00011 Finished Remove/Install battery now ! Time used: 744 sec after I press reset Device: Voxtel BD50 Checking data, wait... Action: reset Boot... Press and HOLD Power button now ! Connecting, wait... Release Power button now ! Boot Done Set baud... 460800 Set baud Done Check Flash... Flash1: 00B00011 Flash2: 00B00011 Check Flash Done Check space... Reading [eeprom_calibration]... file saved: backup_eeprom_calibration_20080322-170405.40E.bin Reading [eeprom_ffs]... file saved: backup_eeprom_ffs_20080322-170719.40E.bin Check space Done Write... Write Done Finished Remove/Install battery now ! Time used: 319 sec problem not solved after I flash it Current device: Voxtel BD50 Done Loading file v.02... Voxtel-BD50_Main_P5.2_R10.38_RS_Jan-25-2006.40M.bin loaded Loading file v.02... Voxtel-BD50_Flex_P5.2_R10.38_RS_T1.EN.01.40F.bin loaded Loading file v.02... Voxtel-BD50_Resourse_P5.2_R10.38_RS_T3.R1.01_En_Ru.40G.bi n loaded Loading file v.02... Voxtel-BD50_repair_ffs_reset_defaults.40S.bin loaded COM6 [VCP3] selected Device: Voxtel BD50 Checking data, wait... Action: flash write Write: Firmware Write: Flex/Customization Write: Resource pack Skip: FFS/File system Skip: Eeprom Boot... Press and HOLD Power button now ! Connecting, wait... Release Power button now ! Boot Done Set baud... 460800 Set baud Done Check Flash... Flash1: 00B00011 Flash2: 00B00011 Check Flash Done Check space... Reading [eeprom_configuration]... file saved: backup_eeprom_configuration_20080325-144538.40E.bin Reading [eeprom_calibration]... file saved: backup_eeprom_calibration_20080325-144543.40E.bin Check space Done Write... Area: Firmware Erase: Firmware Write: Firmware error: can't start write process error: write stage error: write Write Fail Finished Remove/Install battery now ! Time used: 159 sec after this operation phone not power next I repeat flashing but ... Loading file v.02... Voxtel-BD50_repair_ffs_reset_defaults.40S.bin loaded Loading file v.02... Voxtel-BD50_Resourse_P5.2_R10.38_RS_T3.R1.01_En_Ru.40G.bi n loaded Loading file v.02... Voxtel-BD50_Flex_P5.2_R10.38_RS_T1.EN.01.40F.bin loaded Loading file v.02... Voxtel-BD50_Main_P5.2_R10.38_RS_Jan-25-2006.40M.bin loaded COM6 [VCP3] selected Device: Voxtel BD50 Checking data, wait... Action: flash write Write: Firmware Write: Flex/Customization Write: Resource pack Write: FFS/File system Skip: Eeprom Boot... Press and HOLD Power button now ! Connecting, wait... Release Power button now ! Boot Done Set baud... 460800 Set baud Done Check Flash... Flash1: 00FF00FF error: Flash chip problem, unknown flash chip Check Flash Fail Finished Remove/Install battery now ! Time used: 41 sec what's maybe? p.s. Where located Flash1: 00FF00FF in PCB? If some know please type this flash name. |
6300 dead after flash 6233 dead after flash | mobileZONE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 01:17 |
Dead 9210e Orange UK Dead after flashing :( | PhantomGSM | Trisha & Matrix Flasher | 4 | 05-06-2009 12:02 |
voxtel 2iD dead after flash with infinity box | dhawan_boss007 | Infinity-Box | 9 | 10-23-2008 14:27 |
