Old 03-25-2008, 19:29   #1 (permalink)
charletan's Avatar
Member: 102467
warning do no try to use unlock v177 with infinity
if u try to unlock moto v177 u phone dead
COM9 [VCP0] selected
Action: unlock
Device: V175,V176,V177
Checking data, wait...
Connect...
Press and HOLD Power button...
Connecting...
initial boot phase complete
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 0.1.66
HW version: MOTOROLA_E58S
LP ver: LP1_0166
Flex ver: FLEX_90_63_5B03
cpu id: 08B6
imei eeprom: 35223301045282
required SW version: 0.1.66
sp-locked: 22802.
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _35223301045282_20080325-160701.34E.bin
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
unlock step-5 Ok
error: errorcode#50: eeprom can't be erased
Finished, time used: 55 sec
Remove/Install battery now !
Old 03-25-2008, 19:36   #2 (permalink)
charletan's Avatar
Member: 102467
Action: unlock
Connect...
Connecting...
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 0.1.66
LP ver: LP1_0166
cpu id: 08B6
sp-locked: 22802.
Check Flash-1 Done
Check Flash-2...
reading ...
unlock step-1 Ok
unlock step-2 Ok
unlock step-3 Ok
unlock step-4 Ok
unlock step-5 Ok
if u try restore pckup eeprom show the log
sp-locked: HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _48484848484848_20080325-193308.34E.bin
Check Flash-2 Done
Write...
Writing: Eeprom
eeprom write address adjusted
error: erase failed[48] at 05FE0000
error: Error during write: 05FE0000
Write Done
Failed !
Finished, time used: 59 sec
Old 03-25-2008, 20:06   #3 (permalink)
charletan's Avatar
Member: 102467
now the phone flashed with the good and very good box see the log
COM9 selected
"smart write" active
Action: flash
Write: Firmware
Write: Language Pack
Write: Flex
Skip: Eeprom
Connect...
rom version: 0411
Connecting...
rom code version: 0411
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 0.1.66
LP ver: LP13_0166
cpu id: 08B6
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration __20080325-194006.34E.bin
Check Flash-2 Done
Write...
Writing: Firmware
Writing: Language Pack
Writing: Flex
Write Done
Finished, time used: 1404 sec
the phone still dead TO BE CONT
Old 03-25-2008, 20:15   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Nice to see so interesting story with quite nice thread name.
Did you ever heard something about phone hardware faults ?
Do you know something about flash write error reasons ?
Did you ever tried to make "search" in this forum ?
I think no, so there is no any reason to tell you that thousands Infinity-Box users unlocked V177 in seconds without any problems, that thousands Infinity-Box users repaired thair phones without any problems etc. etc.
Anyway, my friendly advice for man who don't understand what he write here: double check cable, un-check "read imei from eeprom" and repeat flashing, check phone hardware.
In case of any other stupid words like in thread name I'll close this discussion immediately.
Old 03-25-2008, 20:30   #5 (permalink)
charletan's Avatar
Member: 102467
hello i have make unceck read imi the cable setting is correct the flash from
support
and the historique of the phone in the good condition if u like to close this
thread i think u like not the reality???
Old 03-25-2008, 20:34   #6 (permalink)
Member: 130995
If you want to talk about reality you can read in my previous message words selected in bold font.
Old 03-25-2008, 20:42   #7 (permalink)
MR.WNKA's Avatar
Member: 617356
I Unlock 5 v177 phone without problem
Old 03-25-2008, 20:45   #8 (permalink)
charletan's Avatar
Member: 102467
ok ok the box is very goog good good is never error all is good in infinity please closed this ?????????????????????????????????????????????????? ?????????????????,
Do you Try to unlock New T156 with Infinity ? -> Post log here !! Faisal_Computer Infinity-Box 571 01-03-2011 08:10
Warning : Hacker Try to **** everybody using ChavalGSM Nickname on MSN and Sonork UnlockBase.com The Market Feed Back 8 07-30-2009 21:46
L6:08.DO.when try to unlock it says phone not found beneto Smart-Clip 8 02-10-2009 09:05
Worning do not try to unlock sagem cid185,186 mobiles with current setool2 version. Miftahudin SETool2 1 12-24-2008 22:10
DO NOT TRY TO UNLOCK S OR C 35 -V.20 OR HIGHER WITH ZeeSiemensG3.exe! PHONE WILL BE D Joseph x1x to x45/x50 2 10-23-2001 20:48
Page generated in 0.32319 seconds with 11 queries
