warning: invalid identification, ask/rpl calculation reqired is it important ? how i can make rpl throug se client plz guide i am confused when i read message like that M3 [VCP0] selected Device: LG KG200 Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6219:8B02:8B01]... MT6226MA detected boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000001:29EA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [standard] (or higher) generation protocol ver: 04 ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1B.BIN ver. sw2: 7S7330SA00-001-R1B ffs offset/size: 00E00000/00200000 warning: invalid identification, ask/rpl calculation reqired error: rpl file not found: C:\Program Files\InfinityBox\MModule\id.._ARIMA26_05C_PCB01_G PRS_MT6226M_S01.7S7330SA00-001-R1B.BIN_FFFFFFFF_.rpl warning: unknown identification structure: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1B.BIN_FFFFFFFF error: ASK file can't be created, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7330SA00-001-R1B.BIN - make "Read detailed information" operation - send "backup_system_log_..." file to support - make "Read full flash" operation - send flash backup file(s) to support - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update Finished, time used: 60 sec Remove/Install battery now ! |
YES you need to make ask to rpl service... press "Read detailed information" and power on your phone... if done correctly it will be booted and will make ask to rpl service automatically... if its good.. then your phone will be revived! but in your case your phone structure is unknown... you need to read flash and send it to infinity support and wait for new updates.. br |
@brain00000 it's no need to make RPL for KG200, probably it's bug in one of old MModule. Download latest MModule update from support area and use it. |
