Old 12-22-2017, 07:07   #1 (permalink)
Member: 2385950
Sonork: 100.1678371
Thanks Meter: 8
What is This
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048600A3BBEA213B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048600A3BBEA213B
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0x094C0CA09C914CEA22E6CF4168364B59
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : joya82_wet_kk , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Only one records found, and determined as universal
BL : BatteryLevel : 3543 mV
BL : [WARNING] : BatteryLevel LOW!!!
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000000E3000000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_joya82_wet_kk.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:18
Reconnect Power/Cable!
Old 12-22-2017, 07:18   #2 (permalink)
Member: 2394050
Thanks Meter: 47
try to erasre all and write flash again, or try other firmware version, if result same problem then your phone have emmc damage
Enviado desde mi SM-G903F mediante Tapatalk
Old 12-22-2017, 07:25   #3 (permalink)
Member: 2385950
Sonork: 100.1678371
Thanks Meter: 8
Yes Its EMMC Damaged I Rehot This Now This Error Is Showing
Old 12-22-2017, 07:31   #4 (permalink)
Member: 2394050
Thanks Meter: 47
make a emmc reballing or try to change the emmc for other
The Following User Says Thank You to alexdroidcuba For This Useful Post:
Old 12-22-2017, 07:50   #5 (permalink)
shazzmob's Avatar
Member: 2327602
Sonork: 100.1620953
Thanks Meter: 276
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
PartCount : 0014
Operation Failed
Elapsed: 00:00:18
Bro "WHAT IS THIS"
The Following User Says Thank You to shazzmob For This Useful Post:
Old 12-22-2017, 12:34   #6 (permalink)
Member: 2385950
Sonork: 100.1678371
Thanks Meter: 8
Originally Posted by shazzmob View Post
Bro "WHAT IS THIS"
Yes It's Also The Problem :-P
I'm Waiting For ..... When Will It Be Charge ....
Waiting Is Much Boring Task.... What You Say?
Page generated in 0.27098 seconds with 9 queries
