Old 10-09-2007, 13:39   #1 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
Unhappy Is It true???????
hellow product supporter
Is it rue that working with chinese mobile can cause damage to infinity(slim plus).. Cause suddenly there is error during reading flash from chinese phone. I contact resseler & he ask its due to chinese mobile
Is it true that there is warrenty of only smart card not reader. So i m confused, If this happen several time then i think i had to draw my mind to other things with is durable against this type of damages. No one can effort this type of loss if several time this reader problem occur
Hope for quick & positive reply
Thanks
salim
Old 10-10-2007, 11:47   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Box CAN'T be damaged during write/read/unlock (and other) operations (not important is it operations with Chinese or European or American models).
Box CAN be damaged in the next cases:
1. you use wrong cables
2. you apply external voltage to box pins
3. you shortcut box Gnd and +V pins (pin 1 and pins 7-8).
4. other type of similar user's activity (f.e. connect 220v to box, use external power supply with high voltage etc. etc.)
There is no any warranty for box damaged due to reasons 1. - 4. because all this damages can be done only by user's mistake and we take no responsibility for this kind of user's mistakes.
As a result: you must always think when you connect something to box.
Old 10-10-2007, 14:22   #3 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
but sir i mentioned in m y first post that this happen during reading flash of the phone. I use phone battery no external supply & use JTAG cable wich has only RX TX & GND cable so there is also no chance to shorten box GND to V+. & also no matter abt using wrong cable
Thanks
salim
Old 10-10-2007, 19:10   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
what have you damaged? box hardware or smart card?>
Old 10-10-2007, 20:22   #5 (permalink)
.::koolfriend4u::.'s Avatar
Member: 200145
Sonork: 100.1596786
Thanks Meter: 677
hai infinity team..
im shure u will help me out from this trouble..plss
http:///vbb/showthread.php?t=452507
as earlier mentioned in the above thread..now,for my three friends..their infinity box in problm...
all they can able to do work with serial port,but not with rj45 cable slot!!!
could u help me regard this...plsss
thanks in advance
Old 10-11-2007, 04:06   #6 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
@ InfinityHelp Sir,
My box hardware is damaged not smart card.
Now i m using Infinity smart card with Cruiser card reader & using C115 Com cable for Rx & Tx as temporary solution
Thanks
Salim
Old 10-11-2007, 14:50   #7 (permalink)
Member: 148515
hello!
personally I- used box on many phones where i had to find pinout (random connecting rx, tx to phone pins) , but i never burn anything.
this is very strange that your box die in the middle of flashing...
anyway, it can be easy repaired by replacing FTDI ic inside box
Old 10-11-2007, 17:33   #8 (permalink)
sallupat's Avatar
Member: 138982
Thanks Meter: 138
can this replacement cover under warrenty???
Thanks
salim
Old 10-11-2007, 19:21   #9 (permalink)
Member: 148515
hello!
i repeat, by normal use of infinity this IC will not burn out.
possible faults:
Old 10-11-2007, 20:11   #10 (permalink)
Member: 348451
Thanks Meter: 2
Wink
hey man
if damdaged your box and it can't detect any device
u have to contact me on my email and i will guide tohow you can fix your box in your shop
cuz it happened with me twice
Micro box is dead is it true? godwin Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 12-04-2009 15:10
WHO's PRODUCT IS THIS? or IS IT TRUE??? jedinyt Smart-Clip 0 01-24-2007 21:37
IS THIS POSSIBLE - IS IT TRUE - ??? - new virus jascorp9 Nokia Multimedia 5 06-06-2005 10:20
Is It True That Dct4 Restore Imei Is Possible ?? mobilemafia Nokia Multimedia 0 02-13-2003 07:37
IS IT TRUE YOU CAN PUT A GAME ON A1018S GLEN Old Ericsson Phones & Sony Phones 2 12-14-2001 09:21
Page generated in 0.21104 seconds with 9 queries
