Old 09-16-2008, 02:39   #1 (permalink)
Member: 675416
Thanks Meter: 8
needs pin outs..
c1000 needs pin out dual sim pls. help
tnx
Old 09-16-2008, 11:45   #2 (permalink)
Member: 128745
Thanks Meter: 16,936
tnx
Please check this post
http:///vbb/showthread.php?t=584572
The Following User Says Thank You to Infinity-Box For This Useful Post:
Old 09-16-2008, 20:38   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
tnx
Dear Friend,
There are different "Chinese" phones with the same name but absolutely different hardware exist on market.
Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware,
different bottom connectors, different pinouts and and has different firmware, so it's impossible to
give any advice about phone pinout only by phone name.
So we recommend you to include the next information in your request regarding pinout:
1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, you can find pinout by yourself more easy than before,
just check the next detailed description how to get pinout for your model:
1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297
2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
3. if not helps, please read: http:///vbb/showpo...36&postcount=7
4. if not helps, please read: http:///vbb/showthread.php?t=433447
Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en
The Following User Says Thank You to InfinitySupport For This Useful Post:
DAXIAN x999+ 10 pins need pin-out mak_14344 Infinity-Box 3 07-15-2009 22:10
need help cect _t688+ ...cect_i658. need pin outs arfantanveer Infinity-Box 9 12-04-2007 00:34
need pin-outs for processor GEMINI 1F35 205T GSM Programming & Reverse Engineering 2 08-03-2002 19:23
Need pin-out for C45 -=GSM2002=- x1x to x45/x50 3 04-05-2002 11:21
I need pin out for Siemens C30 Spalato NON Siemens Brand (ODM Phones) 0 12-19-2000 12:56
Page generated in 0.14339 seconds with 9 queries
