What are the color codes for rx, tx, and ground. sir, please tell me the color code for pinouts to make cable for any model which color is tx, rx, and ground. There are 5 color in rj45 cable as i want to make cable for zte 2010 there are white, blue, red, black and yellow color wire. i have to use only 3 wires for rx, tx, and ground or all five wires are to be used, please help. |
hello! better to check not by colur, but by position. pin 2, 3 are data pins, pin 8 is ground. in different cables - colurs are different, so to help you- post here wich colurs they are. or better photo- then i will explane. |
ip mart cabel i cat it coler is red yello black orange brounm pls help me wich is rx tx and gnd |
Please, contact to your cable supplier to check what is color for each wire. If you need to see Infinity-Box pinout you can see it in Infinity-Box Shell in Documentation page. We did not provide any kind of information about cables that was produced by different factories, we can talk for sure only about Infinity-Box product. |
can i connact spice s410 with pinder finder |
Hello, You do not need to use PinFinder for this model due to pinout is well known. Just take any RJ45 cable and connect RX/TX/GND from RJ45 cable to phone. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout http://www.infinity-box.biz/download...shell_v112.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
Blue RI Orange DCD Black DTR Red GND Green RXD Yellow TXD Brown CTS White RTS |
Each cable has it's own wire color, there is no any standards for wires colors. |
for any unibox pin no.2 of cable is rx, pin no. 3 is tx and 7,8 ground....u can not define rx tx signals with colour |
reply Quote:
