Old 09-20-2007, 14:39   #1 (permalink)
Member: 475309
Thanks Meter: 7
What are the color codes for rx, tx, and ground.
sir, please tell me the color code for pinouts to make cable for any model
which color is tx, rx, and ground. There are 5 color in rj45 cable as i want to make cable for zte 2010 there are white, blue, red, black and yellow color wire. i have to use only 3 wires for rx, tx, and ground or all five wires are to be used, please help.
Old 09-20-2007, 17:05   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
better to check not by colur, but by position.
pin 2, 3 are data pins, pin 8 is ground.
in different cables - colurs are different, so to help you- post here wich colurs they are.
or better photo- then i will explane.
Old 11-23-2008, 14:08   #3 (permalink)
Member: 378776
Thanks Meter: 20
ip mart cabel i cat it coler is red yello black orange brounm
pls help me wich is rx tx and gnd
Old 11-23-2008, 14:20   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, contact to your cable supplier to check what is color for each wire.
If you need to see Infinity-Box pinout you can see it in Infinity-Box Shell in Documentation page. We did not provide any kind of information about cables that was produced by different factories, we can talk for sure only about Infinity-Box product.
Old 11-23-2008, 14:38   #5 (permalink)
Member: 378776
Thanks Meter: 20
can i connact spice s410 with pinder finder
Old 11-23-2008, 14:40   #6 (permalink)
Member: 130995
Hello,
You do not need to use PinFinder for this model due to pinout is well known.
Just take any RJ45 cable and connect RX/TX/GND from RJ45 cable to phone.
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout
Here is information how to build your own cable: http:///vbb/showthread.php?t=342807
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 02-25-2009, 16:01   #7 (permalink)
RazoR888's Avatar
Member: 870868
Thanks Meter: 126
Blue RI
Orange DCD
Black DTR
Red GND
Green RXD
Yellow TXD
Brown CTS
White RTS
Old 02-25-2009, 19:26   #8 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Each cable has it's own wire color, there is no any standards for wires colors.
Old 02-25-2009, 19:44   #9 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
for any unibox pin no.2 of cable is rx, pin no. 3 is tx and 7,8 ground....u can not define rx tx signals with colour
Old 02-27-2009, 12:12   #10 (permalink)
dreams_bd's Avatar
Member: 772645
Sonork: 100.1591509
Thanks Meter: 176
RJ45 RX TX PIN OUT
Old 02-27-2009, 13:13   #11 (permalink)
GFTELECOM's Avatar
Member: 922273
Sonork: 100.1583612
Thanks Meter: 119
reply
the color cable depanding of the manufacturing for example i use one cable who the color is phone rx is green,phone tx is yelow and gnd is black but the realy thing must know is the j 45 pin(rx=2;tx=3;gnd=7)
The Following User Says Thank You to GFTELECOM For This Useful Post:
rx, tx and ground cable for infinity box ajit bs Infinity-Box 2 05-14-2010 12:06
rx, tx and ground cable for infinity box ajit bs Infinity-Box 8 03-29-2010 14:47
rx, tx and ground cable for infinity box ajit bs Chinese Models & Cloned Phones 8 03-28-2010 15:47
WHAT ARE THE BEST SITES FOR NEW PARTIAL FLASHES AND FULL jj008 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-07-2001 07:25
Page generated in 0.19619 seconds with 9 queries
