what is the correct way to unlock coral 100 dear, i already try to unlock coral 100 using infinity and select zte125 but can't unlock what is the problem . if i put the sim card comming msg sim blocked . what to do pl help me thanks |
Hello, Try this: 1. Make eeprom and flash backup for emergency case ! 2. Make "unlock" operation 3. Enter code (if possible) 4. If it's not possible to enter code flash phone with the next files: ZTE-125_main_ERF-RO-P108A1V1.0.0B08__VDF-P108A1B07-RoFr-RO06_g3dBV2.0 ZTE-125_LP_ERF-RO-P108A1V1.0.0B08__VDF-P108A1B07-RoFr-RO06_g3dBV2.0 5. Make "unlock" operation again Waiting for your results. |
Hello, Any luck with this method ? |
thanks i will try and post result |
SIR pl help me all done with you instruct but same problem thanks |
Hello, What you see at phone LCD when you insert sim card ? |
no luck with this method everything flash and unlocks, but no way to put the code. This is what the phone says(itis a weird language) blocarea SIM cauzeaza blocarea ME and left choice is only for emergency call: Urgenta I need to know if I should flash another pair of flash files and which one, or if there is any other method, I flashed and unlocked as Coral 100 model |
Hello, Please, if you have some time, try to use another firmware + lp pairs, let's see results. |
Hello, Please, try to use this new Pana01 v1.56 software: http://www.infinity-box.com/download...na01_v1.56.rar We are waiting for your results. |
