Old 10-22-2008, 12:50   #1 (permalink)
Member: 283763
Thanks Meter: 102
what is the correct way to unlock coral 100
dear,
i already try to unlock coral 100 using infinity and select zte125 but can't unlock what is the problem . if i put the sim card comming msg sim blocked . what to do pl help me
thanks
Old 10-22-2008, 15:45   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Try this:
1. Make eeprom and flash backup for emergency case !
2. Make "unlock" operation
3. Enter code (if possible)
4. If it's not possible to enter code flash phone with the next files:
ZTE-125_main_ERF-RO-P108A1V1.0.0B08__VDF-P108A1B07-RoFr-RO06_g3dBV2.0
ZTE-125_LP_ERF-RO-P108A1V1.0.0B08__VDF-P108A1B07-RoFr-RO06_g3dBV2.0
5. Make "unlock" operation again
Waiting for your results.
Old 10-23-2008, 17:19   #3 (permalink)
Member: 130995
Hello,
Any luck with this method ?
Old 10-23-2008, 18:46   #4 (permalink)
Member: 283763
Thanks Meter: 102
thanks i will try and post result
Old 10-24-2008, 04:32   #5 (permalink)
Member: 283763
Thanks Meter: 102
SIR pl help me all done with you instruct but same problem
thanks
Old 10-24-2008, 08:49   #6 (permalink)
Member: 130995
Hello,
What you see at phone LCD when you insert sim card ?
Old 11-12-2008, 07:00   #7 (permalink)
Member: 220595
Thanks Meter: 355
no luck with this method
everything flash and unlocks, but no way to put the code.
This is what the phone says(itis a weird language)
blocarea SIM cauzeaza blocarea ME
and left choice is only for emergency call: Urgenta
I need to know if I should flash another pair of flash files and which one, or if there is any other method, I flashed and unlocked as Coral 100 model
Old 11-12-2008, 12:02   #8 (permalink)
Member: 130995
Hello,
Please, if you have some time, try to use another firmware + lp pairs, let's see results.
Old 11-14-2008, 14:16   #9 (permalink)
Member: 758852
Thanks Meter: 13
http://forum.gsmhosting.com/vbb/show...ral+100+unlock
Old 11-21-2008, 13:55   #10 (permalink)
Member: 130995
Hello,
Please, try to use this new Pana01 v1.56 software:
http://www.infinity-box.com/download...na01_v1.56.rar
We are waiting for your results.
What is the correct way to change Charge connector e250 samih127 Samsung Hardware Repair 7 02-15-2011 11:34
What is the correct way to connect the mobile phone in the box? marcopolod Z3X-Team Products 1 01-26-2010 09:34
what is the correct way to write rpl how? jackyivan Universalbox 4 05-08-2009 14:56
what is the correct way to write rpl how? jackyivan Universalbox 0 05-07-2009 13:49
OK,we need to knwo , what is the correct way tu unlock LG3?? dynamic-gsm HWK 3 12-21-2005 20:14
Page generated in 0.17563 seconds with 9 queries
