05-19-2016, 06:42 | #1 (permalink) |
No Life Poster Join Date: Sep 2008
Member: 860880 Status: Offline Thanks Meter: 83 | what this error massage mean? Chinese Miracle II [MTK module] v 1.47 Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 65 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 700100563130303038068FD41D875249 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBE0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:59 Reconnect Power/Cable! |
05-19-2016, 07:26 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, This error mostly means phone is fully erased. Just write good firmware to phone. In few cases it could be hardware fault also. Br. Infinity Box Support Team. |
11-04-2016, 06:56 | #3 (permalink) |
No Life Poster Join Date: Jul 2013 Location: gsm forum
Member: 1984655 Status: Offline Sonork: 119.30.39.25 Thanks Meter: 81 | symphony v45 Operation : HW Test [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001A39709B292F5 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBE0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! |
