Old 10-28-2009, 05:44   #1 (permalink)
shamshad quresh's Avatar
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
what is this infinity team?????????????/
I have chiness bb13 mt6225 cpu i read full flash and when i click the touchscreen calibrate and give full flah file then an error, here is log please check and ruply. i aslo format the set change imei and rapair security area but nothing. Any solution .............
COM4 [VCP0] selected
module v2.95
Action: touchscreen calibration
How to calibrate touchscreen:
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.02...
BB13_PCB01_GPRS_MT6225_S00.BB13_BLE_L7EN_204_08031 3_HRILI9320_SIV0_TO75_CTF_BT_FM__fullflash_2009102 6-214240.B0M.bin loaded
error: unknown ffs structure
error: can't detect eeprom structure id
error: operation failed !
Finished, time used: 7 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to shamshad quresh For This Useful Post:
Old 10-29-2009, 14:04   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
module v2.95
Hello,
Try to use latest ChineseMiracle v2.96
Post here your results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-31-2009, 05:52   #3 (permalink)
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
I try with new module 2.96 but same results.
The Following User Says Thank You to shamshad quresh For This Useful Post:
Old 10-31-2009, 23:56   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
please show 2,96 log
Old 11-01-2009, 05:48   #5 (permalink)
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
COM3 [VCP0] selected
module v2.96
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Old 11-01-2009, 06:14   #6 (permalink)
Member: 144565
Thanks Meter: 71
try to backup again full flash with lower speed, then try again, hope it helps....
br,
gioguanez
Old 11-01-2009, 07:36   #7 (permalink)
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
Brother i am tired reading full flash. i try almost 4 times with high and slow speed but faild. I think any product supporter give us a solution.
Old 11-01-2009, 16:43   #8 (permalink)
Member: 148515
hello!
please upload this firmware to www.rapidshare.com.
we will check what is wrong
Old 11-02-2009, 04:41   #9 (permalink)
Member: 898041
Sonork: 100.1593459
Thanks Meter: 549
sory sir customer is gone and recently format my pc and old data lost.
Old 11-02-2009, 18:00   #10 (permalink)
Member: 148515
hello!
turns out that we have this flash file on support.
we will check why this was happening and make improvements in next CM release
KP320 flashing error WHAT IS REASON infinity team sajidashraf Infinity-Box 8 11-16-2009 13:08
what is this sc team ware is chi mei option and ware is imode option rajabrotherscom Smart-Clip 14 02-16-2007 00:25
what is this fg team vk200 vk4000 totaly free rajabrotherscom FuriousGold 0 02-14-2007 08:42
WHaT iS THiS @ FURIOUS TEAM???????? .::BHATTI::. FuriousGold 16 11-25-2006 09:23
Page generated in 0.21680 seconds with 10 queries
