12-29-2009, 06:01 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | What is the reasons of this phone ???? format on ffs safe mode or not write 2nd imei no. Plese help & good reply from infinity team. |
12-29-2009, 14:09 | #4 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | SOME LIKE THAT MT 6225 CPU S3 SET FORMMAT COMPLITE THEN SHOW Action: read/check information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Software date: MT6225, E0 Barcode: GINWAVE25_06B_HW imei-1: FXD-S3_FOREIGN_ imei-2: 2006.06.14" imei-3: MT0123456789012 Finished, time used: 14 sec Remove/Install battery now ! THIS SET NOT PROPAR WRITE IMEI. |
12-29-2009, 20:06 | #5 (permalink) | |
If you lost that thread, please, let me know and I'll make "search" and post my previous explanation again. | |
12-30-2009, 05:32 | #7 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | Quote:
Okey I understand your problem little bit. your problem is that when you try to format your phone with safe mode it turn on and then turn off And till the end of 100% your phone turn on and off. If this is your problem then the reason is that your pinfinder do not supply the required Power. There is a diod in PinFinder remove the diod and try again. Problem will be solved. To see the diod picture goto "Documents' folder of your infinity installtion Package and find PDF file about pinfinder. See the picture and remove the diod. Some Chines phones (having big speakers and lights on sides) also do not work after removing the diod Because it needs more power. So I can give you a solution to get rid of such problems. Before the negitive(-) and positive(+) pins of pinfinder that you use as a bettery, give a little cut and show the wires. Give power from supply. Attatch negitive pin of supply to negitive wire that you haved cutted and do same as positive. Fix the supply power to 3.7 and problem will be solved to all phones that required more power. Note: only supply power or battery do not work pinfinder If your problem solved then post the result BR FarihaBest | |
What is the reasons of this error on n70 set. | debmobile | HWK | 5 | 09-11-2009 23:36 |
What is the reasons of this error.??? | debmobile | Infinity-Box | 2 | 09-05-2009 17:25 |
What is the reasons of this error.??? | debmobile | HWK | 5 | 09-05-2009 05:24 |
What is the reasons of this error.??? | debmobile | HWK | 4 | 09-03-2009 08:07 |
What is the reasons of this error on nokia3500c flashing. | debmobile | HWK | 0 | 11-04-2008 13:33 |
