02-14-2015, 21:49 | #1 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | What Is The Solution For Block eMMC IC ? Some Times I'm Facing This Problem, In Karbonn A20,A26,A99. (Mostly MediaTek eMMC) Cellphone Users Face This Error, Unfortunately Google Has Stopped, Or Unfortunately the process com.google.process.gapps has stopped" Many More Error. So I Tried With These Solution But Not A Single Work On It. Reset, Hard Reset, Format, Flash With Factory Firmware, Whole Format & Flash. But Not A Single Date Erase/Delete. Lots Of Time Flash Done But Problem Not Solve & No Images Delete, No Video Delete, No Music Delete, No Other Files Delete, Even No Version Change, If I Flashed With Different Version Flash File. All Data Is Show As Before Flash. What Is The Solution ? Thank You In Advance. |
02-15-2015, 18:33 | #4 (permalink) |
Banned Join Date: Nov 2014
Member: 2300899 Status: Offline Thanks Meter: 5 | Hi Looks like we face same problem in SD card format the SD card but all things come back .So there is no way to receive the SD card . Like above eMmc is same if we can recover SD card then sure emmc Its my thinking Let's wait For Master.. |
