10-25-2017, 14:06 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | What we NEED to ADD in INFINITYBOX END 2017 * UNIVERSAL DA [NO need download 4GB Etc.. stockroms for just singe operation eg:- FRP,READ PATTERNS,RESET LOCKS etc...] -USE CUSTOM LOADERS OPTION [Incase BUILT-IN FAILED] * UNIVERSAL SPRELOADERS * DO ATLEAST 4 OPERATIONS WITHOUT RECONNECT/DISCONNECTING PHONE * REPAIR BT & WIFI * READ & WRITE SECURITY BIN FIlE [FLASHMODE][This helps to write correct IMEI WITHOUT TYPING,Also can help users where imei write is a CRIME.] * CHECK EMMC STATUS BEFORE FLASHING [This help Technician to kill a semi-dead phone] * MEMORY TOOL -MTK FEATURE PHONES * SPUNLOCK * IMPROVE MTK6276 CM2-AST V1.02 * ADD HTC FULL SUPPORT - FRP - FLASHING - CHANGE MODES - FACTORY RESET Etc.... HTC-TEST Code: Operation : Identify [ v1.01 ] Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! INFO : version: 0.5 INFO : version-bootloader: 1.57.0000 INFO : version-baseband: 4T.28.3218.04 INFO : version-cpld: None INFO : version-microp: None INFO : version-main: 6.13.708.1 INFO : version-misc: PVT SHIP S-ON INFO : serialno: HT35CW920114 INFO : imei: 355859051321297 INFO : meid: 00000000000000 INFO : product: m7_ul INFO : platform: HBOOT-8064 INFO : modelid: PN0714000 INFO : cidnum: HTC__622 INFO : battery-status: good INFO : battery-voltage: 4126mV INFO : partition-layout: Generic INFO : security: on INFO : build-mode: SHIP INFO : boot-mode: FASTBOOT INFO : commitno-bootloader: dirty-6d8a0b9b INFO : hbootpreupdate: 11 INFO : gencheckpt: 0 INFO : Done! OEM : [ERR] Command error !!! Done! Elapsed: 00:00:05 Code: Operation : Reset Settings [ v1.01 ] Mode : Format FS Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! Error set FB mode! Trying skip ... Block [1] ERASE FAIL! Block [2] ERASE FAIL! Error exit FB mode! Trying skip ... Done! Elapsed: 00:01:07 Code: Operation : Change Device Mode [ v1.01 ] Mode : RECOVERY Waiting for device in fastboot mode ... 1. Power off device. Press and hold 'VOL DOWN' button 2. Insert USB cable, hold button until device will be found! Connect Ok! CMD NOT accepted! [RESTRICTED] Done! Elapsed: 00:00:17 * MEMORY TOOL * READ FLASH WITHOUT RECONNECT/DISCONNECTING PHONE. * ENABLE DIAG MODE [for factory Reset in OLD 8810/6820] * IMPROVE READ PATTERNS[to save userdata] CM2SPD FEATURE TOOL V1.28 BASED ON SPD6531 & 6530 * IMPROVE FORENSIC [READED CONTACTS NOT UNDERSTOOD] CHECK HERE DUMP & READED CONTACTS * SPUNLOCK CM2 QLM V1.16 * ENABLE QLCM 9008 PORT FOR SOME OPERATIONS * SPUNLOCK * NORMAL MODE TO EDL MODE CM2 MODERN HUAWEI V1.00 [Just a SUGGESTION 50 Credits OR LESS FOR ACTIVATION] Team will DECIDE * HUAWEI full SUPPORT ----ANY ADDITIONAL INFO TO THIS THREAD IS HIGHLY APPRECIATED------ -CORRECTION TO THIS THREAD IS WELCOME. Last edited by Kirumira; 10-25-2017 at 14:12. |
The Following 22 Users Say Thank You to Kirumira For This Useful Post: |
10-25-2017, 14:58 | #2 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | No need additional Huawei Module, all support for Huawei device should add to CM2 AST and Team should include all feature, such Read, write, FRP and etc... |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
10-25-2017, 17:14 | #4 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
I have never seen any team on this Gsm Planet FULL supports all free services for:- -Huawei Hisilicon -Huawei QUALCOMM -HUAWEI MODEMS -Huawei MTK Maybe,as we call it CHINESE MIRACLE 2 Will make This MIRACLE 3 for FREE. | |
The Following 3 Users Say Thank You to Kirumira For This Useful Post: |
10-25-2017, 19:04 | #8 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Africa
Member: 2601900 Status: Offline Thanks Meter: 519 | Thank you for this kind suggestion.i want #qlm imei repair, all methods. #qlm universal unlock via adb #huawei mtk imei repair and unlock.(hilscon is always paid) #the biggest update will be vodafone/alcatel imei repair(mind you its otp) #spd 8810 its old but most popular chip #samsung write cert,write qcn,unlock and imei #htc module introduced. #hard locked mtk/spd unlock |
The Following 3 Users Say Thank You to mmtheo For This Useful Post: |
10-25-2017, 19:11 | #9 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | i think for a future update support most wanted brand phone (xiaom qlc/mtk ; Oppo; MEIZU; Alcatel; Huawei ;zte ...etc) mtk secured boot mat be 85% supported to services only but for flash you need original signed firmware |
The Following User Says Thank You to rebainoor For This Useful Post: |
10-25-2017, 23:26 | #10 (permalink) |
Junior Member Join Date: Mar 2013 Location: biafra land
Member: 1892935 Status: Offline Thanks Meter: 4 | *CM2 tool should improve on LG support, frp on 6.0. *Improve on samsung module reset userdata without data lost from 2.3 to 7.0. *build qualcomm network unlock for all qualcomm chips. *improve mtk backup. reset userdata on 6.0 to 7.0 * auto select boot on spd chips. * htc module with reset code,factory reset without adb * support zte and huawei unlock and frp Thanks best regards |
The Following 3 Users Say Thank You to fav2010 For This Useful Post: |
10-26-2017, 11:38 | #15 (permalink) |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 827 | Yes i want to Add All MTK Secure Boot With Any DA Or Auth File |
The Following 2 Users Say Thank You to ahmer5050 For This Useful Post: |
